Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 02-12-2007, 11:41 AM
buickpoor buickpoor is offline
Question 2000 lesabre-hard starting sometimes
Well, back again with more Buick quirks. I have a 2000 lesabre (87,431 miles) that sometimes acts like its flooded. when you 1st turn it over and it doesn't start it smells flooded. When you try again to start it, it stumbles a bit and just keeps spinning over. Sometimes I can get it to start by pumping the gas at the right time, after I have spun it over for a while and it is no longer stumbling. It only does this when cold, always starts right up when warm or after running just a minute or two. no codes generated, at least no check engine light. any suggestions appreciated.
thanks
buickpoor
Old 02-12-2007, 04:50 PM
Bassasasin Bassasasin is offline
Re: 2000 lesabre-hard starting sometimes
A leaking fuel injector could be flooding the engine.
For a leaky injector try some injector cleaner. They just get clogged and leak and flood during the prime during a start.
You may try holding the pedal all the way down after a NO Start condition.
Ignition module or Crankshaft sensor may not be working well when cold.
For Spark troubleshooting, get the car really cold and look for spark with a spark testor while cranking.
Good Luck
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
Old 05-17-2007, 10:49 PM
Thanks, I replaced the ignition module and 3 coil packs and had one more episode of hard starting. I started using Snows fuel injector cleaner. Seems to start ok in the morning. Now I get minor stumbling when going up hill just holding speed, not using a lot of gas pedal. could it be spark plug wires? still no trouble light or any codes...
buickpoor
Old 05-18-2007, 08:06 AM
maxwedge maxwedge is offline
A990 racer
A misfire can cause that, dirty injectors, low fuel pressure also. BTW, look for any fuel residue in the vacuum hose to the fuel pressure regulator.
Old 12-11-2007, 06:14 PM
RPerformance RPerformance is offline
maxwedge, did you ever fix this problem?
Old 12-11-2007, 06:23 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Sorry but please check the date and do not resurrect old threads per AF and Buick forum guidelines. See link below.
http://www.automotiveforums.com/vbul...d.php?t=635166
Note: Maxwedge did not have this issue.
Thread closed.
Timeslip 08/12/06
AF Community Guidelines
Closed Thread
