Go Back   Automotive Forums Car Chat > Buick > General Discussion
Old 02-12-2007, 09:18 AM
polarzak polarzak is offline
Dealer Logo Removal?
How can one remove the dealer logo they put on new cars.
It is not the decal kind, but the chrome (perhaps chromed plastic) kind that seems to have a 1/8 thick foam on the back, and then this is glued to the car.
I don't want to advertise for these jerks.
Thanks.
Old 02-12-2007, 10:00 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Dealer Logo Removal?
Heat it with a hair dryer until it is good and warm and then peel it off. You may still have some sticky stuff left on the paint that can be removed with mineral spirits or bug & tar remover.
Good Luck!
Old 02-12-2007, 10:07 AM
Good Luck!
Thanks for the quick reply, however, will this work for the stiff chrome type logo. Mine is not the thin decal type, but similar to the real chrome Lucerne name on the trunk.
Thanks.
Old 02-12-2007, 10:33 AM
HotZ28's Avatar
AF Moderator Elite
Yes, it probably uses something similar to 3M trim tape to secure it to the body. Enough heat and persuasion will eventually remove it. I always remove them from new cars, regardless of the dealer/buyer relationship! One thing I use, is a plastic putty knife wrapped with masking tape & then insert behind the chrome, to pry it off.
Old 02-12-2007, 10:41 AM
Thank you, Sir. I will give it a try.
Old 02-14-2007, 06:45 AM
Noticed several other Lucernes today, and on the trunk of them all on the left side was BUICK and on the right side LUCERNE. It looks like my dealer removed the BUICK mark, and replaced it with their name. Now I wonder if the original BUICK was attached by drilled holes, and the dealers logo is stuck to the paint and covering the holes. As much as I hate the dealer logo, I would hate to remove their ugly logo, only to have a couple of gaping holes. Can't see from inside the trunk if there are hole. Anybody know if the trunk might have holes?
Thanks.
Old 02-20-2007, 07:16 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Thanks.
I'd say that having holes from the emblems/ decals on a new car is unlikely. Every decal I've seen is stuck on with 3m double sided tape. Do you see if there are any holes on the other side of the trunk?
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 02-20-2007, 08:13 PM
BNaylor's Avatar
BNaylor BNaylor is offline
I've debadged alot of GM cars through the years and all I've seen is the 3M type adhesive on the emblems. Another way to remove them after applying heat with hair dryer or pro type heat gun is to use dental floss. Doesn't damage the finish.
Timeslip 08/12/06
AF Community Guidelines
Old 02-21-2007, 06:40 AM
Thanks all, for the replies. Well, there were no holes in the trunk. I heated the dealer logo with my daughter's blow dryer and used dental floss, (Thanks bnaylor) and it came off.
