Old 10-01-2002, 05:33 PM
ragt20's Avatar
ragt20 ragt20 is offline
Send a message via AIM to ragt20
optical illusion
dunno if you've seen it before...I think its pretty cool........
Old 10-01-2002, 05:51 PM
Heep's Avatar
Heep Heep is offline
Send a message via AIM to Heep Send a message via MSN to Heep
I don't believe it. The B block is darker than most of the light grey blocks, but the A block is the shade of the B letter, not the block...
________________________________________
Mark Brown
1991 Volkswagen Jetta (1.8L I4/5-speed/FWD)
Old 10-01-2002, 05:54 PM
ragt20's Avatar
well you gotta believe it as it is true...heheh....will post explanation and an easy way to see why it is true
Old 10-01-2002, 06:04 PM
Heep's Avatar
Of course having the letter A light and the letter B dark helps in creating the illusion, I still don't think the blocks are the same shade.....
Mark Brown
Old 10-01-2002, 06:06 PM
ragt20's Avatar
thats what I thought when I first saw it as well...but it all becomes clear when you see the explantion on how it is........trust me
Old 10-01-2002, 06:07 PM
Twist's Avatar
Twist Twist is offline
I don't believe it, but he is telling the truth. Took it into Paint Shop Pro and checked the RGB values.
Red Value = 107
Green Value = 107
Blue Value = 107
Great illusion, ragt2.0!
Initialize your Dreams!
Master of the invisble post...
Old 10-01-2002, 06:11 PM
Heep's Avatar
Red Value = 107
Green Value = 107
Blue Value = 107
Yeah I just did that too...they are the same, but I still don't see it
Mark Brown
Old 10-01-2002, 06:13 PM
ragt20's Avatar
if ya still can't see it I can PM you on how to easily see it....
Old 10-01-2002, 06:15 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
I saw this a couple days ago on a different forum. I didn't see it then and I don't see it now. The guys on the other forum posted this other pic saying that this one is easier to see, but I cant see this one either
Old 10-01-2002, 06:17 PM
I've always liked this one. It's fun to look at
Old 10-01-2002, 06:30 PM
ragt20's Avatar
wow....just given me a headache there.......even though I've seen that one before..
Old 10-01-2002, 06:34 PM
www.eyetricks.com has a whole bunch of these. some are actually really good
Old 10-01-2002, 06:38 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Old 10-01-2002, 06:41 PM
ragt20's Avatar
Originally posted by ci5ic
I suppose now everyone will see it
Old 10-01-2002, 06:48 PM
ragt20's Avatar
now that ci5ic has shown it does work and how you can see it....................for the technically minded this is why it works....
:flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash: :flash:
The visual system needs to determine the color of objects in the world. In this case the problem is to determine the gray shade of the checks on the floor. Just measuring the light coming from a surface (the luminance) is not enough: a cast shadow will dim a surface, so that a white surface in shadow may be reflecting less light than a black surface in full light. The visual system uses several tricks to determine where the shadows are and how to compensate for them, in order to determine the shade of gray "paint" that belongs to the surface.
The first trick is based on local contrast. In shadow or not, a check that is lighter than its neighboring checks is probably lighter than average, and vice versa. In the figure, the light check in shadow is surrounded by darker checks. Thus, even though the check is physically dark, it is light when compared to its neighbors. The dark checks outside the shadow, conversely, are surrounded by lighter checks, so they look dark by comparison.
A second trick is based on the fact that shadows often have soft edges, while paint boundaries (like the checks) often have sharp edges. The visual system tends to ignore gradual changes in light level, so that it can determine the color of the surfaces without being misled by shadows. In this figure, the shadow looks like a shadow, both because it is fuzzy and because the shadow casting object is visible.
The "paintness" of the checks is aided by the form of the "X-junctions" formed by 4 abutting checks. This type of junction is usually a signal that all the edges should be interpreted as changes in surface color rather than in terms of shadows or lighting.
As with many so-called illusions, this effect really demonstrates the success rather than the failure of the visual system. The visual system is not very good at being a physical light meter, but that is not its purpose. The important task is to break the image information down into meaningful components, and thereby perceive the nature of the objects in view.:flash: :sun:
Off topic.... Optical Illusion RichSpidizzy Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 09-07-2003 10:36 PM
Optical Illusion Oz COMPLETELY off-topic 11 08-19-2003 03:36 PM
Optical Illusions Shortbus COMPLETELY off-topic 9 03-20-2003 09:17 PM
Optical Illusion Jonno COMPLETELY off-topic 6 11-11-2002 11:20 AM
eye test? Optical Illusion!!!! ragt20 COMPLETELY off-topic 22 01-07-2002 04:04 PM
