Old 02-11-2007, 10:25 PM
Derk_eliso's Avatar
Derk_eliso Derk_eliso is offline
Send a message via AIM to Derk_eliso Send a message via MSN to Derk_eliso Send a message via Yahoo to Derk_eliso
quick dumb question
do certain cars take certain injectors or are they just kinda like...universal?
Old 02-11-2007, 10:44 PM
shakewell shakewell is offline
Re: quick dumb question
with a few exceptions, they are specific to the vehicle. there are high performance injectors to replace oem, but even those are usually specific to the vehicle. in other words, you cannot just put corvette injectors into your cavalier (if that's what you were sort of asking)
Old 02-12-2007, 12:08 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
They are pretty much put any injector you want on your car. The wiring clips will be different, so they would have to be wired up for the correct pigtail. However, they all flow different amounts. If i recall correctly the 2.2L OHV are 18-19lbs high impedance and the 2.4L are 24lbs. However, ford brown tops clip into the stock clips, and they are low impedance just like the 96-98 injectors. They are 370cc or 35lb/hr injectors.
There is a lot of math involved with switching them around, but yes you can pretty much run w.e you want. But your going to need a FMU to control the fuel
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 02-12-2007, 01:32 AM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Thanks for numbers CRJ. Interesting, twin cam has like 4-5 more psi in there injectors.. Im sure that makes a decent diff when u think about it.
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 02-12-2007, 09:21 PM
Derk_eliso's Avatar
yeah, okay thanks guys. The reason being, when I get my turbo installed I want to up the injector size...not because it's an almost manitory upgrade to get anything out of the turbo, but because my injectors need replaced. I was thinking like 450cc, but I don't want to like mess anything up, lol. The 370cc ones, was that the ford brown tops? is that their name? Ford Brown Tops?....and where could I buy them? Thanks in advance
Old 02-13-2007, 03:28 PM
Lifted GMT-360!
You can get the off e-bay. In our shops turbo'd 2.2 we are running injectors from a 3400 V6 engine.
Old 02-13-2007, 11:22 PM
Derk_eliso's Avatar
thanks cody, thanks everyone
Old 02-13-2007, 11:26 PM
Derk_eliso's Avatar
so kinda like these then?
http://cgi.ebay.com/ebaymotors/2002-...spagenameZWDVW
Old 02-15-2007, 09:01 PM
Derk_eliso's Avatar
so do you think this would be a good buy then? anyone?
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old 02-15-2007, 09:13 PM
jerseycavyz24 jerseycavyz24 is offline
I think im gonna go with RC engineering 440cc
www.handsdownnj.com
Old 02-15-2007, 09:52 PM
Lifted GMT-360!
In order to select the correct size injector for your application, you might wish to use one of the following formulas.
In most cases a naturally aspirated engine will have a B.S.F.C of .50. This means that the engine will use .50 lbs. of fuel per hour for each horsepower it produces. Turbocharged engines will want to be at .60 lbs. per hour or higher.
Using these numbers as a guideline, you can select the approximate injector size in the following formula for a four cylinder, naturally aspirated engine at 200 bhp.
Most injectors will max out at 80% duty cycle and this is the accepted industry standard.
B.S.F.C is brake specific fuel consumption - How much fuel you are using per horsepower per hour
reference page used..
http://www.rceng.com/technical.htm
Old 02-15-2007, 10:13 PM
Derk_eliso's Avatar
Thanks Cody. I think the 3400 ones are 25lb ones.... So the 200hp were you basing that on what my car will be when turbo'd or....? I'm confused where the 200 came from, lol.
