Old 10-01-2002, 04:46 PM
dhcarss dhcarss is offline
Send a message via AIM to dhcarss Send a message via Yahoo to dhcarss
intake qwestion
Is the delsol intake the same in any way to the 88 si intake, I have a 88 crx I guess it is the dx, Its not the hf but it dosnt have the multi port intake, It has the single throtle body, but I have this delsol motor with the intake and all, the motors bad but I was wondering if it would work on my motor.
3geez member since Feb 12, 2001
Old 10-01-2002, 07:39 PM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
why dont you just try it? it would only take like 20 min. max to try it on
Old 10-03-2002, 11:18 AM
Im talking about the intake manifold, not a intake tube. Also would it be worth it to put a motor out of a 87-89 teg in the crx, have possible good deal on one. or is it a waist of time.
Old 10-03-2002, 11:26 AM
91zc 91zc is offline
If the intake manifold from the del sol is the sohc verison it will bolt up but you are going to need to convert your fuel injection to mpfi. The 87-89 integra motor will not bolt into your crx. It has different mounts and there is not a mount kit available. Anyway it only has 118 hp.
91 civic 4dr
b16a
14.8@94
Old 10-03-2002, 04:06 PM
What is needed to do that, the comp, harnes, and pump?
240sx s14 CARB Legal Cold Air Intake? Dope Minded Technical 3 01-26-2011 03:48 PM
Intake gasket or head gasket?? mandymae104 Century 3 07-10-2009 09:31 AM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 10:20 PM
3.8 Intake Removal problem Jakal Park Avenue 2 05-23-2009 03:19 PM
'00 cavalier, odd noise and oil in air intake/throttle body warik Cavalier Problem Diagnosis 4 04-23-2009 06:11 PM
