Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 02-11-2007, 05:47 PM
I_Like_Cars I_Like_Cars is offline
Question 02 Malibu Coolant Flush
I'm having trouble locating the plug to drain the coolant in my wife's '02 Malibu. It has build up around the pressure cap so I definately need to change the coolant. Can someone fill me in on where that plug is? Thanks.
Old 02-12-2007, 01:28 AM
Negatoro Negatoro is offline
Send a message via AIM to Negatoro
Re: 02 Malibu Coolant Flush
I assume 3100 v6? How many miles?
I remove the lower hose to drain radiator.
There are two drain plugs on the block.. one between starter and oil filter, one near crank sensor.
-Mark T.
Old 02-13-2007, 12:00 PM
My bad, yeah 3100cc V6. I found the one on the lower right hand side on the radiator itself but I couldn't locate the block drains. But your info does help. Thanks a lot Mark.
-Simon
BTW-73,500 mi
Old 02-13-2007, 10:14 PM
wymi wymi is offline
Change your coolant bottle cap if it's the original one.
Old 02-14-2007, 01:14 PM
yeah, I think I will do that
Old 02-15-2007, 01:15 AM
If you change the puke tank cap, make sure you get an OE replacement with the same pressure rating.
If there's any buildup inside the tank, it's a pretty good idea to remove it from the vehicle and soak it real good, then flush the hell out of it.
-Mark T.
