Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-11-2007, 04:23 PM
gophercollectables gophercollectables is offline
1989 Firebird Won't Start
89 Firebird, 305 engine, 5.0 litre, automatic
When you turn the key, nothing really happens, but there is a clicking at the starter relay and at the vapor canister. The battery is fine, and all cables to it are tight. We bought a new relay from AutoZone and installed it, but the car still will not even attempt to turn over. There is still a clicking in the vapor canister. Does anybody know what the problem may be? Thanks.
Any help would be appreciated. Thanks.
Old 02-11-2007, 05:00 PM
Morley Morley is offline
Re: 1989 Firebird Won't Start
The relay at the vapor cannister is supposed to energize with the key on, but it has no relation to the starter turning over. Is your security light on all of the time when the key is on? If so you have a VATS (Vehicle Anti Theft System) problem. If not, read on.
Go to your local auto parts store and get a remote starter switch. This is a push button switch (heavy duty) with leads that you hook up at the starter (it will have directions with it). Turn the key on and hit the remote switch. If the car cranks over you need to check the starter enable relay. This is located behind the driver side kick panel. Bypass it and see if the car will start/crank with the key. If it does, replace the relay. If it still won't start, remove the shifter knob and the shifter cover plate. Mounted on the shifter bracket is the park/neutral switch. If this has gone bad (I've seen this happen) or if it has somehow shifted position it will cause your problem.
Old 02-12-2007, 04:35 PM
It was my starter enable relay in the kick panel. Thanks alot for your help!
Old 03-18-2007, 09:32 AM
jeff84red jeff84red is offline
I am having the same issue with mine except I have a five speed. HE car will start fine, shut it off and then I turn the key and nothing. Wait a few minutes and it starts.
Old 03-18-2007, 08:40 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Jeff, sounds like you may have the VATS security issue there. Does the security light come on and start blinking when this happens?
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 03-19-2007, 09:08 AM
Update: I traced this down to a broken wire leading to the lock cyclinder. Both wires have plenty of cracks and I decided to purchase a new lock cylinder and going to get a new key cut today. I tried to fix the wires but each time I soldered the two peices together, the engine would fire but the wires continued to crack insulation and short. After 228 K miles it was time to replace the parts.
Thanks, Jeff
Old 03-20-2007, 06:48 AM
WoW! I can't believe that it lasted for over 200k miles. The one in my '89 Formula only lasted about 60k miles. Instead of paying for a new lock though I just went to RadioShack and spent $3.86 for the parts to bypass it.
Pioneer 4900mp
Orion C63 Coax rear
