Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-11-2007, 11:33 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Power Steering Porblem...
Lately, my power steering has been sucking ass. Sometimes, it's a little hard to turn the wheel while going slow. No biggy, but a hassle sometimes. When I turned the wheel then, it would make a squeeking sound from the steering wheel. Yesterday (before I got shit-faced), I was making a quick sharp turn in front of a car coming head in the opposite direction, and I lost all power steering half way through. Kinda scarey when you're going kinda quick and turning hard.
I haven't checked the fluid yet, which would probably give me an answer. It's cold outside. But it could be the pump if there i fluid? What else?
Oh yeah, remember when my antifreeze froze? Well I overflow the tank and radiator as usual, and it's been leaking out on my belt, making it sqeak. Could the belt just me slipping maybe? Maybe I should go outside.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-11-2007, 01:32 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Power Steering Porblem...
My power steering blows ass if my car is not warmed up since it's been so cold around here. After 5-10 mins of driving though it goes back to almost normal. I would say it may be related to the cold.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 02-11-2007, 02:12 PM
david-b's Avatar
Dave is THAT guy
It does it when the car is warm though now.
75 Monte Carlo
Old 02-11-2007, 04:32 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Check the fluid. Do you hear a whining or humming noise when you turn the wheel?
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 02-11-2007, 04:45 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
If there's antifreeze leaking on the belt, it shouldn't be slipping so much that you're losing power steering, it would just make a wicked squealing noise for awhile. Definitely check the fluid level, I'm guessing it's low. If you run it empty and seize up the pump, you'll snap the accessory belt, and I'm sure you don't want to be changing that outside in the cold now do ya? The fluid is most likely just low.
95 Talon TSI AWD
97 Eclipse GST
Old 02-11-2007, 05:38 PM
david-b's Avatar
Dave is THAT guy
I just checked it and it's showing full. It's not really bolted on to anything so it was sitting sideways slightly. I adjusted it and going to run it to see if that helps some. But there's plenty of fluid in it as is. Well see when I get home and go out tonight.
75 Monte Carlo
