Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 02-11-2007, 07:19 AM
92 tracker 92 tracker is offline
fuel problem
i have a 92 tracker that wont start it has fuel inj. if i put gas into the carb it starts and continues to run but wont start on it own.i hear a clicking noise at the carb when the key is on.is it the injector in the carb?
Old 02-11-2007, 07:26 AM
Scrapper Scrapper is offline
AF Premium User
Question Re: fuel problem
sounds like weak fuel pump...
Old 02-11-2007, 07:48 AM
Re: fuel problem
thanks i was afraid that might be the problem
Old 02-11-2007, 01:56 PM
njp3737 njp3737 is offline
Re: fuel problem
My father is having a similar problem with clicking sounds under the hood, and a tracker that won't start without injecting something into it mannually. I've done some searching and most seem to think they need to replace the ECU/ECM. We don't think it is a fuel pump problem either since it runs fine once it is started... any other thoughts?
My fathers description of whats happening:
The check engine light came on while I was driving. Still
ran fine, until I shut it off. Then when you turn the
key on, the fuel pump relay clicks (on and off) really
fast, and it won't start. Out on the engine on the
fuel injection plenum there is a cylindrical
controller with wire connected to it that is also
clicking. You can unplug it, and the clicking stops.
The engine will run once you supply enough fuel
manually to get it running (spraying lots of
carburetor cleaner through intake).
Old 02-11-2007, 07:14 PM
lovemytracker lovemytracker is offline
Re: fuel problem
A friend of mine was having the same problem. He changed the computer now it starts fine. Now the problem is it is drinking the gas. Any suggestions???
Old 02-12-2007, 02:09 PM
AF Premium User
Exclamation Re: fuel problem
you may have to just your fuel relay..and even if it starts...but a weak fuel pump can drive you nuts if you put spray in it and starts don't mean the fuel pump isn't going out..you should have had it tested..good luck...
Old 02-16-2007, 03:33 PM
baumbr baumbr is offline
Re: fuel problem
This is a classic symptom of a bad ECM. Have it checked and repaired if necessary. Many, many people have thrown money away on fuel pumps and injectors when a $60 ECM repair fixes the problem.
Old 02-25-2007, 12:33 PM
iamatracker iamatracker is offline
Re: fuel problem
check your fuel filter, or just replace it. The pump in the gas tank is a big job and the original pump is a good one. Replacement pumps that are not O.E.M. are just not the same. Filters are cheap and last a long time if your tank is clean.
Also maybe repalce the relay for the pump, it's under the dash on the same bracket as the ECM.
Old 03-23-2007, 09:32 PM
Re: fuel problem
I had my ecm repaired and the car is running fine,thanks for the help.
another question.When my tracker turned 240,000 the check engine light came on how do I turn it off so I can know if it's fixed.
again thanks for your help
Old 03-24-2007, 08:36 AM
AF Premium User
Re: fuel problem
take it too autozone or advanced let them check it for free because you just can not turn it off. you might try taking neg. cable off for about 5 min.
then put it back onsee gos out...good luck..
scrapper....
