Old 02-10-2007, 06:44 PM
dirtydx dirtydx is offline
need help with my alarm
it's a viper alarm, I don't have a remote to shut it off.
i dont know how to dismantle it. All i've done is unhooked the battery for the night.
anyone know if there's an easy way to remove it, i never use it in the 1st place. I dont care if i have to cut wires or whatever, i just want my car to shut up.
"I just threw away a lifetime of guilt-free sex and floor seats to every sporting event in Madison Square Garden. So, please, a little respect, for I am Costanza, Lord of the Idiots."
Old 02-10-2007, 06:55 PM
Re: need help with my alarm
i have an extra remote but its not calibrated.
maybe someone knows how to set it up.?
its a viper rpn491. as pictured here http://cgi.ebay.com/DEI-Viper-replac...QQcmdZViewItem
Old 02-10-2007, 07:09 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Well, you can use the valet switch, it has a preset amount of times you can push it to shut it off. I think its 3 by default, but youll have to look in the book. You can also just cut the wires and be done with it. That is unless it has an immobilizer on the ignition.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 02-10-2007, 11:26 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
cant u just disconnect the alarm or is it hard wired? why dont u just find the product support for ur alarm online and program the remote urself.
Old 02-11-2007, 09:37 AM
i can't find anything, DEI customer service is closed until tommorow.
my car is undriveable, i was hoping somebody had valuable information.
Old 02-11-2007, 09:38 AM
plus the valet switch does shit all.
it keeps going off and my battery is already drained.
Old 02-11-2007, 10:06 AM
well dude it isnt hard to find the brain..it could be located tucked up behind the glove box behind the black heating duct..or tucked away on the drivers side in the left corner up in that area..cant u trace the wire from the starter kill which would be right under ur stealing colum when u remove the fuse panel..? the brain is in there..juss gotta put lil more effort forward to find it and disconnect it. ive wired several alarms and the 2 positions i said is where i always installed um..hard to find and a bitch to get to
Old 02-11-2007, 12:37 PM
FrodoGT's Avatar
Mines under the center console.in front of the shifter and behind the metal frame, under the stereo. Talk about a bitch to find.
Current project:
Rio Red 91 hatch.
Old 02-13-2007, 07:03 PM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
disconnect the whole alarm, they splice it into the ignition so open your fuse panel and follow the wires for the alarm to find the brain and undo the alarm
Old 02-13-2007, 07:29 PM
FrodoGT's Avatar
lol, yeah, it completely replaces your ignition.
Current project:
Rio Red 91 hatch.
Old 02-13-2007, 11:49 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
you can unplug it at the brain and have it work....most alarms are cheap whether a good brand or not...I can turn of 99% alarms on the market and drive away without ever having alarm go off again...just an early warning device I rather go with LoJacks!
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 02-14-2007, 12:09 AM
ok so 2 other guys gave the same advice..have u found the brain and disconnected yet? how did u make out?
Old 02-14-2007, 05:48 PM
u cant jus disconnect the brain, an alarm installed suppose to disconnect the ignition circuit until its disarmed an complete the circuit to allow it to start, if u unplg the box the circuit is open an wont start u have to reconnect the wires for the ignition
Old 02-14-2007, 06:41 PM
i had alarms with starter kills and the car started find..if u disconnect the relay it wont start
Old 02-15-2007, 06:51 AM
they wernt installed right or were cheap alarms...
