My van will not start
Hello, I have a 2003 T&C. I parked it last week and it hasn't turned on since. I've changed the starter. To no avail. I've changed the battery, still dead. I've changed the ignition switch still doing nothing. I've changed relays and no response. When I turn the ignition to run the relays just click. If anyone has any suggestions please let me know. Thanks
Re: My van will not start
1. Do the interior lights come on when you open the door? 2. If you put the ignition switch in ACC postition will the radio come on? 3. Will the headlights come on? 4. Do you have a voltmeter and know how to use it? 5. What relays did you change?
Retired USAF/ Nuclear Plant Controls Dude Had Recently 1996 Caravan 3.0 Great Car 2005 Impala 3.8 Now 2000 GC 125K 3.3 2006 T&C 3.8 |
Did you check the "neutral safety switch"? Your starter won't engage if this has failed "open" or it is misadjusted.
"This car may be old, but it will still climb Kirker Pass at 110!" 1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible |
Thanks for replying
1. Do the interior lights come on when you open the door? Yes 2. If you put the ignition switch in ACC postition will the radio come on? Yes 3. Will the headlights come on? Yes 4. Do you have a voltmeter and know how to use it? Yes, not really 5. What relays did you change? Starter Relay and Accessory Relay |
Thanks for the reply, I will look into it.
If the new battery was not charged before you installed it, I would disconnect one of the terminals and put a charger on it for a few hours. Make sure the terminals are clean before you hook it back up. Remove the battery charger then and give it a whirl. Let us know how it goes.
Sorry it's taken so long to get back to you. i do apologize. The battery was charged. It would not turn on. I changed the ignition switch but still will not turn on. Disconnected the computer and reconnected the computer, it then turned on for a while but began to heat up pretty bad. also i'm wondering, i have a sentry key for the ignition and when i try to turn on the van the alarm bulb light stays on, could it be the sentry key? thanks for your reply. By the way we also put a scanner on it and it reads "no codes"
According to Chrysler, this model van 2003 T&C 3.3L does not required one.
what kin of key do you have, a black one, gray one or one with the rke together
A grey one
Since then the van started once but begin to overheat, then died again. Any Ideas anyone?
