Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-10-2007, 02:48 PM
Killa's Avatar
Killa Killa is offline
Check Engine light, 3 code
Finally I have time and go to autozone, for check engine light and print out the code, to post here.
Code 1: P0125
The PCM had determined that the amount of time it took for the coolant temperature sensor to reach a input value consistent with closed loop operation was too excessive.
Code 2: P0100
The PCM had determined that a malfunction exist in the electrical circut for the mass air flow or volume air flow sensor. This code point toward a possible wiring problem, ie: short to ground, short to power, or an open circuit.
Code 3: P0170
The PCM determined that during testing, the fuel compensation value for bank 1 exceeded the specified range. ( Bank 1 indentifies the location of cylinder #1, while bank 2 identifies the cyclinder on the opposite bank )
The car run ok, I fell it weak cause the valve cover bolt is trip, so it loosing pressure, running stock blow off valve so I have boost leak, bad gas miles. Please help me the best you guy can, thanks alot -Killa-.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 02-10-2007, 03:49 PM
Scrapper Scrapper is offline
AF Premium User
Re: Check Engine light, 3 code
you can take the maf sensor apart and clean the screen..as i've done this a few times and it works.
good luck...
Old 02-10-2007, 04:48 PM
Killa's Avatar
good luck...
MAF sensor ?
GM FOR LIFE !!
95 camaro lt1
Old 02-11-2007, 08:45 AM
Killa's Avatar
Any one have any ideal, what other code mean ?
GM FOR LIFE !!
95 camaro lt1
Old 02-12-2007, 12:27 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
The P0125 is a CEL for the coolant temp sensor. Basically the ECU isn't being shown that the vehicle is up to operating temperature and therefor isn't entering closed loop.
Be aware, that the coolant temp sensor for the gauge is not the one used by the ECU. There are 2 different coolant temp sensors located on the thermostat housing. One for the gauge and one for the ECU. So the gauge could show that you are up to temp, but the ECU is "seeing" something else.
I think the sensor is about $23 from the dealer, if I remember correctly.
The P0170 is a "Fuel trim malfunction, Bank 1" CEL. This means that the ECU is out of it's adjustment range to compensate for what it believes is a rich or lean condition. This is normally caused by a bad O2 sensor, but could very well be a product of your P0125 CEL.
Do you have a logger?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 02-13-2007, 11:57 AM
Wick3D-PimP Wick3D-PimP is offline
Send a message via AIM to Wick3D-PimP
coolant temp sensor is about 16$ and i can bet when u replace it that 3rd code will disapear too... one of the functions of that sensor is to run your engine leaner under cold conditions.. thus "fuel compensation value for bank 1 exceeded the specified range".
Id replace that temp sens 1st then reset ur ecu.. then test again.
1996 Eagle Talon ESI
Old 02-14-2007, 10:28 PM
Killa's Avatar
How do I replace that collant temp sensor that run into ecu ( that the one I need replace right ?, if I go to dealer what should I tell them ? )
GM FOR LIFE !!
95 camaro lt1
Old 02-16-2007, 09:54 AM
Tell them that you need to Coolant Temperature Sensor for the ECU and not the one for the gauge.
It's bolted in the thermostat housing. If you do it quick enough, you can just unscrew the old one and replace it with the new one without loosing too much coolant. Just make sure the car is cold when you do it......We don't want you to get burned with hot antifreeze.
1997 Spyder GS-T
5-Speed
Old 02-16-2007, 08:39 PM
Killa's Avatar
Thanks guy, I call the dealer and got it quote for $55, So I went to autozone get one for $20, I replace it sunday, its bad to run the car like that ?
GM FOR LIFE !!
95 camaro lt1
Old 02-21-2007, 10:31 PM
Killa's Avatar
Can any one tell me where is MAF or MAS sensor locator ? cause I heard those can be clean, what can I use to clean them ? thanks
GM FOR LIFE !!
95 camaro lt1
Old 02-22-2007, 09:35 AM
You will be running in limp mode if the ECU doesn't see the car is up to operating temperature. It won't hurt anything, but I wouldn't go on a 1,000 mile road trip.
You are just going to be running pretty rich, so I might suggest that you replace your plugs when you get the CEL's fixed.
1997 Spyder GS-T
5-Speed
Old 02-22-2007, 09:38 AM
If you open your hood, you will find the MAS in the lower left corner of the engine bay. If you have an aftermarket filter, such as a K & N, the filter will be directly attached to the MAS. Let me see if I can find a picture......
Here you go, it's the orange dot:
http://members.shaw.ca/dsm.1000q/Eng.../2G/aircan.htm
You really souldn't have to clean the MAS, unless you have a shitty air filter, but you can easily inspect the MAS just by pulling the filter off.
1997 Spyder GS-T
5-Speed
