Go Back   Automotive Forums Car Chat > Opel/Vauxhall > Corsa/Barina
Old 02-10-2007, 12:50 PM
Choder boy Choder boy is offline
Corsa Engine Cutting Out
Hi can anyone advise on an annoying problem?
The car drives fine until it loses power temperality or cuts out, once this happens the rev fails to response if the car is still running however will drive fine. If the car cuts out and may take 5 to 30 mins to restart the car, if it does restart the rev fails to response again.
Please respone if you have any ideas.
Thanks
Adam
Old 06-12-2007, 11:05 AM
CorsaT CorsaT is offline
Re: Corsa Engine Cutting Out
HI there i am not sure if this is the cause to ur problem, but a friend had a similair problem with his Corsa that it would cut out sometimes, but never had it that it would battle to start. I checked the car and found that the fuel pump relay had dry joints on it, i soldered those dry joints and the car is 100% after that
