Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 02-10-2007, 07:50 AM
specialedd specialedd is offline
2003 impala LS 3.8 hards shifts
can anyone help me my impala when i give it gas is a little sluggish then it kicks in then switches into gears hard.i believe my car is also and ex-police car if this helps you help me.ive changed plugs wires fuel filter trans flush and trans filter oil change maf sensor
Old 02-16-2007, 09:31 PM
troy1 troy1 is offline
AF -Advisor
Re: 2003 impala LS 3.8 hards shifts
possible bad cat or pressure control solenoid. do you have the "check engine" light on?
Old 02-17-2007, 04:38 AM
my check engine light is on.how can i check my cat or pcs?
Old 02-17-2007, 08:34 AM
crazy Jim's Avatar
crazy Jim crazy Jim is offline
did you have the transmission trouble before you flushed it? Flushing it could have caused some debris to lodge in a valve actuated by a solenoid ie:"pressure control solenoid".
master airframe mech/shadetree auto mech/30+ years experience
current vehicles:
'02 Impala LS 3.8L
'02 Trans Am WS6 LS1 6spd
'99 Grand Am SE 3.4L
'71 Cutlass SX 455/TH400
'04 YZ450F
'07 Kona Garbonzo (dowwnhill mountain bike)
Old 02-17-2007, 11:28 AM
i dropped the tranny pan let the fluid leak out changed filter and put pan back on filled up and still the hard shifts.is the pcs in the tranny or on the outside that i could change without opening the tranny?
Old 02-17-2007, 09:52 PM
AF -Advisor
PCS is not a DIY job. I would get your car scanned for codes sense the SES is on. usally P1811 <<the harsh shift code will not turn on the SES. Go to your auto parts store they usally scan for free. (Autozone, Parts America)
Old 02-19-2007, 11:07 AM
2005chevimpala's Avatar
2005chevimpala 2005chevimpala is offline
unhook your neg bat terminal for 30 seconds ,hook it back up, then start your car up,let her idle for 60 secs, shut her off again for 30 seconds then start her up and drive her around the block to see if she is any better, this should reprogram your shift patterns for you tranny, thats what the g.m teck at the assemble plant who is the tranny tect did with my car, works fine now, better then it did when brand new, now mine has 30 000km's and since reseting the computer manually the car shifts as smooth as butter.
