Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-10-2007, 01:52 AM
cantgo2fast's Avatar
cantgo2fast cantgo2fast is offline
Fuel Cut
I just got a 3inch exhaust and DP and when im on the throttle 90-100% i get fuel cut usually between 5500-6500rpm and only in 1st or 2nd gear and it wasnt doing it before the exhaust
but i dont know why?
1995 GSX 2Gb bumper
Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5/Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/
Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs
Wish list:
CAMS
Old 02-10-2007, 02:43 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Fuel Cut
New pump and minimum 550 injectors, get them and you'll be good.
95 Talon TSI AWD
97 Eclipse GST
Old 02-10-2007, 01:45 PM
Re: Fuel Cut
i have walbro 190 but i didnt think 11.5 psi could cause fuel cut with the 16g
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 02-10-2007, 02:23 PM
Re: Fuel Cut
You're still running stock injectors. Do you have any type of logger to see exactly how bad your damaging your engine?
95 Talon TSI AWD
97 Eclipse GST
Old 02-10-2007, 10:47 PM
Re: Fuel Cut
unfortunately not. should i not drive it until i can get it tuned. Should i be really worried now?
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 02-10-2007, 11:55 PM
steviek's Avatar
steviek steviek is offline
Re: Fuel Cut
nah thompson is just scaring you... Yea you can mess it up by knocking the shit out of it while running too lean but if you havne't thrown a rod yet your still ok...sorta. You could have done damage to your engine but really 450's are just not enough get an afc and some bigger injectors.
On a side note.. thats why Mitsubishi stopped making eprom ecu's and has a/f run at about 9.5/1 on a stock tune for people like this
you can drive it just don't boost the shit out of it
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 02-11-2007, 01:23 AM
Re: Fuel Cut
Drive it like a grandma got it. But i didnt think the evo3 16g could
stretch the stock fuel system like that
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 02-11-2007, 08:22 AM
steviek's Avatar
Re: Fuel Cut
yea it can flow 42lbs/min. That murders the stock t-25. It really is a bigger turbo supports about twice the horsepower. Think of it in those terms and you see why the it can really hurt you.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 02-11-2007, 04:52 PM
Re: Fuel Cut
Undersestimating my turbo apparently. I was thinking of getting 750 injectors those should work now and into the future when i push the 300 hp mark right?
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 02-11-2007, 06:57 PM
Re: Fuel Cut
Yes, they'll be enough.
95 Talon TSI AWD
97 Eclipse GST
Old 02-11-2007, 11:51 PM
Re: Fuel Cut
Thanks for the help/ advice
1995 GSX 2Gb bumper
Wish list:
CAMS
Old 02-12-2007, 08:37 AM
steviek's Avatar
Re: Fuel Cut
just wanted to make sure you gotta have some form of tuning tool when you get those 750 afc won't really be able to help you since the injector size is so much higher than stock. 680's will manage the 16g and you can still use afc. Just wanted to add that on.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 02-12-2007, 11:17 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Fuel Cut
Yeah, 750's are too big for SAFC. I would just 650's, I think those will do you fine and thats about as big as SAFC can handle. Until then, dont hit boost and you should be fine.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 02-12-2007, 12:15 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Fuel Cut
Fuel cut is caused by reaching a preprogramed airflow value within the ECU and has nothing to do with fuel delivery. Have you check for leaks? Running the 16g @ 11.5psi is not enough to hit fuel cut.
Do you have a logger?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 02-12-2007, 05:52 PM
Re: Fuel Cut
thats what i thought i have not checked for leaks. wouldnt a leak lower the amount of airflow??
1995 GSX 2Gb bumper
Wish list:
CAMS
