Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-10-2007, 12:14 AM
knl25 knl25 is offline
rough idle 95 ZJ
My 95 gc 4.0 idles very rough especially when it is in reverse or drive. I just had a tune up and fuel injectors serviced. My spark plugs are coated with carbon, the plug threads seem wet and smell like gas. I took a vacuum measurement off of the intake manifold port and is is -17Hg in park, -14 in reverse and drive. My fuel pressure is at 36PSI with key on engine off and 42PSI with engine on.
Does it sound like I have a vacuum leak? I checked around and cannot locate one. Does fuel pressure seem high also?
thanks for reading
Old 02-11-2007, 03:32 AM
hardisk_c's Avatar
hardisk_c hardisk_c is offline
Re: rough idle 95 ZJ
Was this issue present before the tune up or did Jeep start running rough immidiately after?
Old 02-11-2007, 09:11 AM
The tune up was done in the process of trying to get rid of my idle problem.
My inspection of the engine mounts revealed a bad mount on the passenger side. Since the mounts have been in the car for 205K miles, I think I will have them replaced to see if it helps.
Have anyone done this job yourself?
