Old 02-09-2007, 11:01 PM
squeaky3 squeaky3 is offline
problem
ok i have a problem
ok so i got my car and i went and put my headunit in becuz the old stereo was shot
i hooked it up and when i turn the unit on when the car is just in the on position w/o the engine runnin the speaker is fine
but when i have the engine runing it emits a high pitched static kinda noise
it is the stock speaker but i plan on puttin the speakers i have for it into the car soon
will puttin new speakers in fix my problem or is there something else as my problem??
Old 02-09-2007, 11:47 PM
jtvyper456's Avatar
jtvyper456 jtvyper456 is offline
Send a message via AIM to jtvyper456
Re: problem
Sounds like you're having a grounding problem...make sure the ground wire has a good connection.
1995 Camaro
40 Series Flowmaster
2 Kicker Comp 05CVR 122 (Dual 2Ohm Voice Coils)
^Kicker ZX550.2 Amplifier^
Old 02-10-2007, 08:36 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: problem
do you have aftermarket amps ?
Old 02-10-2007, 11:47 PM
Re: problem
the only thing i have done is hook up the new headunit
the only ground i hooked up was the one tat screwed into the back of the old unit and i hooked tat up to the ground cable on my wiring harness
i dont have ne aftermarket amps for the speakers
i will soon have an amp and sub to put in but i dont want to put them in until i can get my speakers to work rite
the only speaker tat makes the noise is the front passenger side one
i need some help
Old 02-11-2007, 08:06 AM
PlayStation3 PlayStation3 is offline
Re: problem
are they stock speakers? and what car are you having a problem with.
Old 02-11-2007, 11:39 AM
Re: problem
rite now they r stock speakers
i plan on puttin in new speakers soon
the car is a 94 plymouth sundance if tat helps ne
Old 02-11-2007, 05:00 PM
Audio Guy
Re: problem
interesting, try pulling the cd player out and moving the wiring harness over some. In fact, try playing it with the c d player out of the dash cavity with the car on.
Old 02-11-2007, 10:48 PM
Re: problem
ok i think i will try that tomwor in my autos class becuz i dont have nething else to work on then
there isnt much room to stuff the harness when i put the stereo in though so wat should i do if it works when the unit is out
i dont really want to cut into things
should i try puttin the new speaker in and c if it still does it?
Old 02-12-2007, 05:59 PM
Audio Guy
Re: problem
if you are using the factory wiring for the speakers, changing the speakers will not help. If pulling out the cd player helps, then you will need to move the wires around somehow .... and yes I know, it's usually a very tight fit back there. If it doesn't help, take the ground wire from the cd player out of the harness and connect it directly to something metal back there.
Old 02-12-2007, 09:20 PM
Re: problem
ok well i put the new speakers in and it still did it
im thinkin now tat maybe i accidently hooked up the positive to the negative when i put in the cd player
would it make a high pitched noise all the time if i did tat??
tomarow i may change the wires around to c if tat is actually the problem
if not idk wat to do becuz tat cd player was a pain in the rear to put in
Old 02-12-2007, 09:40 PM
Re: problem
it might be that but i think your speakers would do that but not totaly sure
Old 02-13-2007, 12:46 PM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: problem
no, it wouldn't do that. it might if you connected somthing like the ground wire or power wire to the speaker.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 02-16-2007, 05:00 PM
chopper1982 chopper1982 is offline
Send a message via MSN to chopper1982
Re: problem
the first respons was the best u need a better ground
