Old 02-09-2007, 07:58 PM
manlystanley manlystanley is offline
Transmission slipping
Hello Everyone,
My 95 (3.3 L) Plymouth Grand Voyager's transmission is developing a transmission slipping problem. Every once in a great while (like once a month) when taking off from a complete stop the engine reeves, but the van does not move. Then when trying it again the transmissions then seems to kick in.
The van has 139K miles on the first transmission. Also, We bought it with 90K miles on it and I'm assuming that it never had a transmission service.
I'm not sure what I should do? We only use the van 2-3 times a week for short trips (5-10 miles). Should I chance doing a transmission service on this old of a vehicle? Or should I just continue to lightly use it until it dies??
Any words of wisdom would be greatly appreciated.
Thanks,
Stan
1995 Plymoth Grand Voyager; 1998 Volvo S90, 2000 Ford Ranger, 2002 Dodge Grand Caravan.
Old 02-09-2007, 08:14 PM
Re: Transmission slipping
Oh, forgot to add: Transmission fluid is full. The color is red (not pink). Also, the slipping just happens when its in drive.
Thanks for your help.
Best Regards,
Stan
Old 02-10-2007, 01:04 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Change the fluid and filter and see what happens. I have a 96 GC with 195k miles and change the fluid annually.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 02-11-2007, 05:41 AM
RIP, Thanks for the advice. I've done transmission services on my other vehicles, but didn't do it on my 95 because I had been told that replacing the fluid on a vehicle with such high mileage (with the original fluid) had a good chance of causing a transmission failure.
Thanks,
Stan
Old 02-11-2007, 11:58 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
I wouldn't use one source for a decision like that. Read up on it. How do you know the fluid was never changed?
Keep in mind too that when you change the fluid in the normal way, you're only changing about a third of it. At least consider pumping the fluid out, changing the filter, check the magnets, then put the fluid back in. If you change it don't use Dexron. Use AFT-3 or 4.
We are talking about the 4 speed 41te tranny right? If it's the 3 speed you can adjust the bands.
