Old 10-01-2002, 05:54 AM
Bong_the_Monkey Bong_the_Monkey is offline
Send a message via ICQ to Bong_the_Monkey
Dragster Suspension
ALright, here is my problem. My mid-engine El Camino is dead! It is now a dragster El Camino. I removed the bed floor and have a wheel and axle fit so that it fits inside the box at a stock or lower height. Now my question is, how does the suspension work in top fuel dragsters? I need to know because it is the axle from an old top fuel dragster. The only thing between the wheels is the differential, there is no axle hardly. Also what should I do about a frame for around the wheel/axle section? Any ideas?
Old 10-01-2002, 05:57 AM
Purpura Delujo Purpura Delujo is offline
Top fuels have suspension!?!? Never knew that!
Old 10-01-2002, 06:59 AM
TerminalVelocity's Avatar
TerminalVelocity TerminalVelocity is offline
Send a message via AIM to TerminalVelocity
maby post this somewhere other than car modling...unless you mean this is your modle....
My new RHD project!
Solid Crew (Circa 2002)
Old 10-01-2002, 09:09 AM
astroracer's Avatar
astroracer astroracer is offline
Top Fuel dragsters have no rear suspension... The rear axles are bolted directly to the frame. The rear tires are the only "suspension" these cars see. You may be able to modify a T/F rear frame section to work in your Elky.
If you want a rear suspension I would suggest starting with a Pro-Stock car. They have a generic 4-link with coil overs and you could adapt the rear frame/suspension to your truck a little easier.
I also have a lot of rear suspension and drag car parts on my website if you are interested in turned aluminum and photo-etched parts. Check my site at: www.mas-parts.com
Mark
Old 10-01-2002, 08:18 PM
I only have the axle and tires from the kit, so I can't use part of the original T/F kit in my 1/24 El Camino. I was thinking of just attaching the axle to the frame but wasn't sure if that would be possible in reality. Another idea is to make a bracket type affair that goes on top of the differential then two small coilovers/springs attach the bracket/axle to the frame. Does this seem like a possible setup?
Suspension for my truck RoudyRides Engineering/ Technical 5 04-19-2010 06:59 AM
2000 venture suspension noises/woes pjw73nh Venture 27 02-28-2010 08:01 PM
ZR2 suspension 4x4chevymanS10 Performance 10 08-14-2009 11:45 PM
2001 Interceptor version, suspension problems... ratherbestrummin Crown Victoria 0 07-22-2009 06:20 PM
87-91 Camry Rear Suspension Parts F/S nohablaingles Classifieds 0 07-02-2009 10:22 AM
