Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-09-2007, 04:39 PM
97gs-t teamrtv 97gs-t teamrtv is offline
Send a message via AIM to 97gs-t teamrtv Send a message via MSN to 97gs-t teamrtv Send a message via Yahoo to 97gs-t teamrtv
What Next?
Well guys take a look at my sig and you'll see some of my mods. My question to you is what should i get next. I cant really decide between Dsmlink & injectors (already have eprom ecu) or a clutch kit & flywheel. I only have funds for one or the other. My goals are to have eventually no more than 400whp on a 50 trim or equivalent. I am on the stock clutch but it was replaced right before I got the car approx. 3000 miles ago and have no problems with it. Any suggestions?
97 gs-t: Guages: boost, oil pressure and temp, water temp and volts. AEM cam gears, short throw shifter, hks ssqv, injen intake, brembo drilled rotors, akebono ceramic pads, sportline springs & koni ajustables, Strut bars: front, rear and lower rear tie bar. Evo III manifold and o2, megan downpipe, Apexi N1 catback, 16g, 190 fuel pump and FMIC.
Old 02-09-2007, 05:07 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: What Next?
Why replace something that isn't broke? Get link and injectors, and when your clutch finally goes out, then upgrade it, there's no sense in wasting money on a new part when the one you have works just fine.
95 Talon TSI AWD
97 Eclipse GST
Old 02-09-2007, 05:45 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: What Next?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 02-09-2007, 05:59 PM
Re: What Next?
You make a good point. Just for my knowledge, how much hp usually can a stock cluch handle before slipping occurs? I did a search and came up with nothing.
And why is my status a newbie again? lol. I log on atleast once a day.
Old 02-09-2007, 06:07 PM
Re: What Next?
I'm gonna go with the guess that you only have 93 posts so they still consider you a noob...
As for the clutch... If you drive normal and easy the stock clutch will handle a good bit of power. Exact numbers can't be said though as they depend on the exact condition of the clutch and the driver. But if you drive it easy and normal it'll work just fine. Its when ya start driving it hard and beating on it that the stock clutch will start slipping on ya.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 02-09-2007, 08:03 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: What Next?
The only reason I say you might want to do your clutch now is because you will be pushing quite a bit of power if you get injectors and link. That stock clutch doesnt take much to fry up. In my opinioin the clutch might be the better thing to replace now because that is a mod that I would like to do on my own terms rather than when it breaks because you dont know exactly when that is going to happen. Unless you have a daily driver then I would say clutch because its no fun to not have a car.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 02-10-2007, 02:41 AM
Re: What Next?
I'm still saying wait on the clutch, it's a mod that you don't want to do until you really need to.
95 Talon TSI AWD
97 Eclipse GST
Old 02-10-2007, 12:27 PM
steviek's Avatar
steviek steviek is offline
Re: What Next?
yea its not like you have to drop the tranny to add link and injectors they are two completely separate jobs and there's absolutely no gain on doing them separately... However, if you were getting a shep racing trans or something then definitely switch that clutch while your at it.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 02-11-2007, 02:30 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: What Next?
you're rocking all of that stuff without a tuning device??
DSM geek
Old 02-11-2007, 03:14 PM
Re: What Next?
Yes I am but I only have boost set to 12psi. Plus its not an everyday car, its been parked up for the winter.
