Old 02-09-2007, 01:22 PM
russell stanton russell stanton is offline
Sea Foam
After reading so many good things about Sea Foam I decided to buy some. I used it in my 1997 LeSabre and also my 1991 Toyota Camry.
The LeSabre now has the check engine light on (which sucks because I was doing this to clean the engine before taking it to be smogged. The light came on as soon as I restarted it), and the Camry refuses to start up again after letting the product sit in it for 5 minutes. Can anyone give me some advice on these problems?
edit: The Camry is O.K. now . I just had a little moisture in the distributor cap from rinsing the engine.
Old 02-09-2007, 01:32 PM
goldberg_52403 goldberg_52403 is offline
Re: Sea Foam
I put Seafoam in my 97 when I first got it. When I started it up, it idled really rough for 5-10 minutes. I cannot recall if my check engine light came on, but after a while it smoothed out and ran good. Maybe let it run for a while?
Old 02-09-2007, 02:16 PM
Re: Sea Foam
I've put about 100 mi. on it so far. I'll be taking it in to see what code shows up this weekend.
Old 02-09-2007, 02:38 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: Sea Foam
I'd say it's probably a mis-fire code.. I use seafoam every 6 months or so. I put 1/3 in the oil, 1/3 in the fuel tank, and 1/3 gets sucked in the intake.. Good stuff as long as you don't use it too much...or so I've heard.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 02-10-2007, 11:40 AM
Re: Sea Foam
Just thought I'd follow up. The check engine light turned off last night coming home from work. I had put about 150 miles on the car.
Now that I've done the seafoam treatment and removed and cleaned my egr valve I'm going to take it back for a re-smog. Any last ideas for lowering my N0 emmissions would be appreciated.
Thanks
Old 02-10-2007, 09:31 PM
Re: Sea Foam
NOx emmisions are kept under control by the EGR system. High NOx levels indicate high combustion chamber temperatures.
