Old 02-09-2007, 10:59 AM
instructions instructions is offline
89 Plymouth Voyager
In the morning, starts on the first turn. After that, have to crank the starter 6 or 8 times before it starts.
Old 02-09-2007, 01:50 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 89 Plymouth Voyager
With no engine size or maintenance history it's tough to get specific. Easy stuff to start with:
Ignition - Spark plugs, plug wires, distributor cap/rotor, test coil and inspect/clean connections, test battery and clean post connections
Fuel system - can of injector cleaner, listen for pump, tap on fuel tank, change filter
Clean Idle Air Control valve if an 89 has one. Clean throttle body.
Check for fault codes.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
