Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-09-2007, 10:15 AM
BiggWaukegan BiggWaukegan is offline
91 Caprice Very Odd Vibration
Guys help me out on this one please. Took my 91 caprice to breakfast this morning. Drove fine there. Then on the way back I noticed a huge vibration, mostly when I was at or over 40 mph. Seemed like I couldnt even go over 50 or all hell was gonna break loose. Braking was still normal, Im thinking tyrod or maybe ???? Help me out guys. ****ALSO SEEMS TO "WANDER" A LITTLE BIT WHEN THE VIBRATION STARTS. Reply asap please
Old 02-09-2007, 04:46 PM
CD Smalley CD Smalley is offline
Re: 91 Caprice Very Odd Vibration
Worn idler arms?
U-joints?
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 02-09-2007, 06:17 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Tire(s). You have at least one tire that's in the separation process. Mark my words - get that tire replaced ASAP or you could, best case scenario, have a mess to clean up and some bodywork to perform.
Tires flying apart aren't a pretty sight.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-10-2007, 09:05 AM
Hmm. I have had to put air in the front right tire for the past week or so. But how do I know for sure which or which ones are bad? Wouldnt bad tires indicate some other front end problem?
Old 02-10-2007, 09:54 AM
Not necessarily. As Silicon pointed out, a belt seperating could be the culprit. You must likely won't see anything wrong fro mthe outside. Get it to a tire shop and have the tires balanced. If there is an issue with the belts seperating in one, the tire shop should be able to tell you.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 02-10-2007, 12:14 PM
Ok Im gonna get it to the tire shop today hopefully. Man sure hope its the tire.
