Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-09-2007, 10:04 AM
junction boy junction boy is offline
Passport trans leak
My wife has a 200 passport. The transmission was leaking last week. I originally misdiagnosed the leak as coming from the front pan gasket. I got everything back together and it still was leaking. Upon better examination, I found fluid coming out of the rubber stopper looking device right above the front pan. What is this called? This thing is recessed into the transmission just above the front pan on the passenger side. I just need a name or a part number and if anyone has ever dealt with this.
Old 02-09-2007, 11:19 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Passport trans leak
http://isuzufaq.ibctech.ca/#faq57
it's common.
get it fixed asap, these trannies don't like low fluid.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 02-09-2007, 12:17 PM
Thanks amigo. That is exactly what I needed. Now I can just call and get the parts a lot easier. I have never done much transmission work before but this one seems like it is not very well designed just going by what I have heard.
Another question, in refilling the fluid the other day, when I took the tube out after putting about 6 quarts of fluid in, it just started coming out everywhere while I was putting the plug back in. Can I remedy this problem by turning on the engine and putting it in gear (with the brake on) while refilling. How many quarts should it hold. I heard approx. 6-7 quarts.
Thanks!
Old 02-09-2007, 07:10 PM
trooperbc's Avatar
trooperbc trooperbc is offline
about your last question about checking fluid level, yes do it while running. urge you to look up the info in the FAQ, it's important
and to check that part yourself use this alerted to us by 2eye...
http://www.myisuzuparts.com/
it's a great, official, isuzu parts site. it'll keep the counter parts guy 'honest', and faster, too.
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 02-09-2007, 10:52 PM
pharm_rodeo's Avatar
pharm_rodeo pharm_rodeo is offline
While it's running and in neutral.
1994 Acura Integra LS---212K+
1998 Isuzu Rodeo S 3.2L 2WD---176K+
Old 02-10-2007, 03:15 AM
AWILLIAMS64 AWILLIAMS64 is offline
i had the same problem w/ my 01 passport and i had the accumulator cover replaced and have had no problems since.
Old 02-12-2007, 11:14 AM
I just wanted to thank everyone for the info on Friday. I called the local Honda dealer on the way home from work Friday and they actually had the accumulator cover in stock. It cost 13 dollars. After finding the right set of C-ring pliers, I got the old one off yesterday. It was tough getting the new one back in place until I used a socket and a pry bar to finally get it in right. Thanks again for all of the useful information in saving me a lot of time and money.
Old 02-12-2007, 11:56 AM
trooperbc's Avatar
thanks for the followup.
exactly how did you use the socket and pry bar, i.e. what did you use for the leverage point? and getting it off, did you need to use it?
thanks
//bc
