Old 02-08-2007, 08:08 PM
chevcamaro_86 chevcamaro_86 is offline
Thumbs up question?
i want a third generation camaro with a v8(project car) and a stick and i was wondering what a good price would be and if i went to the junk yard what is the highest i should pay
Old 02-08-2007, 08:49 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: question?
depend on what you find and what you want. Do you want interior and make a halfway comfy street car or do you want a gutted race/street car roll cage bit
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 02-08-2007, 09:00 PM
Re: question?
honestly i have a third generationa already that i wanted to use as a project car and it is in good body shape but it has a 2.8l engine and a automatic trans, so i figure that i will just find a 350 small block and swap it out but then what do i do about the transmission its worthless to me first off its automatic and it wont be able to handle the power that i am wanting to put into the 350 and with the prices of the engine and transmissions that ive been finding i am wondering if it will be worth it to just find another cheap camaro with a 350 anda manuel in it already?
Old 02-08-2007, 09:37 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: question?
no thirdgens came with a 350 and manual trans, only with the 305/manual. if you are looking to make big power, the stock t5 manual trans would need to be rebuilt as it can only take about 300ft lbs. also, it will be difficult to locate a v8/5 speed thirdgen in a bone yard because not a ton were made. it would be easier to do an engine swap on a camaro that already had a v8 as there are multiple things that would need to be changed out on a v6 car.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 02-09-2007, 09:35 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: question?
I bought my last Z28 for $400 because the guy thought the piston rings were bad when all it was leaking valve seals and too far advanced timing.
