Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 02-08-2007, 05:40 PM
huckaday huckaday is offline
Question Fuel gage gone psycho
The fuel gage reads full until it reaches about 1/8th of a tank then drops down and bounces from empty to 1/8th reading. Ideas?
Alana
www.huckaday.com
Old 02-09-2007, 09:30 AM
KimMG KimMG is offline
AF - Advisor
Re: Fuel gage gone psycho
Sounds like the sender in the tank has given out. I use the trip odometer in place of a fuel guage in my car. Every two hundred miles I stop and fill up.
Old 02-11-2007, 03:08 PM
Truck Truck is offline
The "Solution" to the problem is to replace the sending unit with the high-pressure pump. It's $120 off the shelf, new. Then you have to deal with taking the tank off, and replacing the unit. (And all that that implies; in other words, it's worth paying someone else to deal with the headache.)
Alternately, you can take the tank off and unit/pump out, and replace the float, only.
-OR-
You can use the odometer to count your mileage, and wait for the pump to give out, as well. You can only purchase the unit with the pump, and it seems kinda silly to replace a pump that's working. I bought a Bronco with a working unit/pump for $125.
