Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-08-2007, 01:51 PM
torlok2002's Avatar
torlok2002 torlok2002 is offline
Oil leaking from PCV hose
Well, Went to the driveway today and found a spot of oil underneath the car. Open the hood and it's coming from the PVC hose, dripping down around the spark plugs and down on the ground.
Any ideas on what is wrong? I did some searches and a bad PCV valve will apparently cause too much pressure in the crankcase... but never any posts i could find with oil actually coming from the hose. The hose on this one is kinda foam-like and it actually appears that some of the oil is seeping through the hose, as well as the hose being too loose on the fittings. I put some hose clamps on each end, but afterwards this is when the oil started seeping through the hose.
I have pics but they are on my phone and I cannot get them off because my cable is at work, I'll have to get the pics tonight or tomorrow. But any help now would be of great help.
Old 02-08-2007, 05:44 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Oil leaking from PCV hose
Replace the $3 PCV valve, hose, and clamps. That should get you on your way.
95 Talon TSI AWD
97 Eclipse GST
Old 02-08-2007, 09:06 PM
torlok2002's Avatar
Will do, but the PCV valve seems to be working fine. I get suction on both the hose before it and afterwards. When I got the car it did not have clamps on it, it put them there to see if it would stop the oil leak.
It just started doing this one day, and the hose appears to be in the same condition as it was earlier.
Is oil even supposed to be in that hose?
Old 02-08-2007, 11:12 PM
Killa's Avatar
Killa Killa is offline
Go to mitsubishi dealer and get the pcv.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 02-09-2007, 11:48 AM
nova1313's Avatar
nova1313 nova1313 is offline
I had the same problem when I bought both my eclipses. It's a simple fix. Replace the pcv as they said and put a new section of hose on. It seems to build up by blowing through a bit (it happens... oil sloshes around in the engine) and then when the hose gets alot it seems to seep through. It's a cheap fix but it works.
Your engine is fine just replace that stuff.
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 02-18-2007, 07:49 AM
torlok2002's Avatar
Thanks all. I replaced the Valve and it appears to be doing much better. I think it still leaks a bit(a few drops every day), but I'll replace the hose when I get the chance and see if thats helps any.
Old 02-18-2007, 01:27 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Just goto Autozone for hose and clamps. Buy a foots-worth and you'll be good.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
