Old 02-08-2007, 01:12 PM
doberman_52's Avatar
doberman_52 doberman_52 is offline
Send a message via MSN to doberman_52
Stoichiometry...
I am completly lost in Chem right now. We are currently doing Stoichiometry... No clue on how to do this crap. I am hopeing somebody here can help me out a bit.
My problem:
How many moles of Ammonium Sulfate can be made from the reaction of 30.0 mol of NH3 with H2SO4 according to the following equation:
NH3 + H2SO4 -> (NH4)2 SO4
I have no idea as to how to set up the problem equation as far as the numbers go.
This is what I do know:
Number of moles given or mole ratio (what you want)
.................................................. what you have
This chemistry class sucks, we have almost no labs (around 5 in the last year), 99% lecture, no actual teacher here, like doing this online pretty much.
1994 Honda Civic - D15B7 W/5 spd
2000 Olds Intrigue - 3.5
Cory
Old 02-08-2007, 01:47 PM
GloriaJeans GloriaJeans is offline
Re: Stoichiometry...
Alright, here it is...
30 mol NH3; 17g/mol NH3; so you have 30 x 17 = 510g NH3
According to your equation, 17.4g (or 1 mol) of NH3 produces 1 mol Ammonium Sulfate. And 1 mol Al. Sulfate is 132g. Thus...
510g NH3 x 1 mol (NH4)2 SO4......x 132g (NH4)2 SO4
..................17.4g NH3..................1 mol (NH4)2 SO4....So 30 mol NH3 made 3869 g of (NH4)2 SO4
But you need moles, so 3869/132 will give you 7.6 mol
Hope this helps!
Old 02-08-2007, 02:07 PM
Yea, it helps a bit. I just have about 30 more problems like this. So you convert the moles to grams find out that, then find out how much of the other chemical you have, then convert back to moles. This is going to be time consuming.
Cory
Old 02-08-2007, 02:12 PM
Once you get the concept, each problem should take you no longer than 2-3 minutes. The method is always the same...
Old 02-08-2007, 02:19 PM
Question Re: Stoichiometry...
Yea, usually math stuff doesn't take me to long if I get it.
Cory
Old 02-08-2007, 04:41 PM
gouldie1903 gouldie1903 is offline
the coefficeints of the chemicals are the mole ratios. the equation must be balanced for these ratios to be true. for the equaion to be balanced there needs to be the same number of each type of chemicals on each side:
ex. 4 H on one side and 4 H on the other
the example you gave appears to already be balanced, but if it was not you would need to multiply the chemicals to balcance out the equation.
once the equation is balanced the coefficients is the mole ratio
in the example you gave the ratio says
1 mole + 1 mole will yeild 1 mole
hopefully this helps if you need clarification on anything let me know
67 chevy c 10 needs paint
01 mustang gt needs hp
Old 02-08-2007, 04:44 PM
That's a good point, but I don't think they're quite that far along yet...
Old 02-08-2007, 05:16 PM
Ok, i miss understood that at first, We are passed balancing equations, but all of our equations are allready ballanced anyway, I think.
Cory
Old 02-09-2007, 10:45 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
I flew threw Organic Chemsitry, Metabolic Biochemistry, and P-Chem at university...but I still can't do, and still fear, stoichiometry. This crap reduces my brain to scrambled eggs.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 02-09-2007, 10:48 AM
Yeah, this is the hardest thing I've done for math/science and normally I have no problem at math anymore, kinda wierd.
Cory
Old 02-09-2007, 06:42 PM
Yeah, organic was interesting...
Old 02-09-2007, 10:36 PM
RalliArt3kGT's Avatar
RalliArt3kGT RalliArt3kGT is offline
Send a message via AIM to RalliArt3kGT
The ONLY thing I remember from Chemistry last year is fuck stoichiometry. That crap raped my grade big time. I'm so glad I'm not going into any field where I need to use science.
-Russ
Old 02-09-2007, 11:30 PM
Me too.
Cory
