Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-08-2007, 11:43 AM
vlajko vlajko is offline
compresion
Hi everyone I recently bought accord type r 1999 with 93000 km passed I have done a compression test and the numbers are 14.1 kPa on each cylinder does it sound right and which octane fuel should I use ,sorry for my bad english.
Old 02-08-2007, 12:50 PM
somick's Avatar
somick somick is offline
Re: compresion
As far as I know the difference is what matters.
If your all cyllinders give you the same readings this suppose to be good.
For the gas: 87 octaine is what recomended and that what I use.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 02-08-2007, 05:06 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: compresion
on a type r? use nothing less than 89...but 91 is recommended.
Old 02-09-2007, 02:48 AM
Re: compresion
I can only find 98 or 95 octane unleaded but what will be the compression like
11:1 10:1 meaning the preasure on each cylinder is 14kPa
Old 02-12-2007, 03:00 AM
Re: compresion
someone
Old 02-12-2007, 08:20 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: compresion
the compression should be 11:1 and as far as fuel, run the highest octane you can get at a normal pump
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 02-15-2007, 12:51 PM
Re: compresion
Yes it should be 11:1 but it looks like the owner did build up the engine the compression was measured with four difrent instruments and it is 14 bar or 14 Kpa*100 and I do have a problem with the fuel at least 103 octane
Old 02-16-2007, 08:44 AM
jclark jclark is offline
Re: compresion
Check this out.
http://macdizzy.com/compress.htm
Jim C.
