Help!1999 Ford Contour ABS replacement cost?
I was just told that the ABS rings are cracked and needed to be replaced. In order to replace the entire front axle must be replaced apparently. The cost quoted was $425 per axle...is this a reasonable quote? Should I try another mechanic?
Re: Help!1999 Ford Contour ABS replacement cost?
is that $425 per axle plus labor or just the cost of parts?
![]() "The CEG Nazi" www.contour.org 1996 Ford Contour SE - Sold 3.0L V6 and Arizona Dyno Chip Turbo Kit 364 whp, 410 wtq @ 16 psi and only 4,700 rpms. 1999 Tropic Green SVT Contour - Bone stock and MINT Last edited by beyondloadedSE; 02-08-2007 at 01:22 PM. |
$425 each includes labor (supposedly). I was told that ford does not sell the rings seperate any longer (I also called the local ford dealership and was actually quoted a higher cost). Is it nessessary to fix the abs?
$425 each includes labor (supposedly). I was told that ford does not sell the rings seperate any longer (I also called the local ford dealership and was actually quoted a higher cost). Is it nessessary to fix the abs? |
Its not neccessary to fix. My 96 didnt come with ABS from the factory. My dads ABS went out on his old F150 and he just left it at that.
![]() "The CEG Nazi" www.contour.org 1996 Ford Contour SE - Sold 3.0L V6 and Arizona Dyno Chip Turbo Kit 364 whp, 410 wtq @ 16 psi and only 4,700 rpms. 1999 Tropic Green SVT Contour - Bone stock and MINT |
