Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-08-2007, 11:53 AM
pov02 pov02 is offline
Dynoing with SPOOL
Hi,
I was wondering if you can help clarify the TRE SPOOL diff for me. My main question is, If I was to get the TRE SPOOL, am I required to get the Viscous Coupling Eliminator for dynoing purposes(FWD dyno)? Also, when I read other forums about dyning an AWD in FWD mode, they said to drop the transfer case and driveline. Now does that mean, literally taking out the complete unit? Please help me clarify this a little so I can tune my 92' GSX. Any reply is appreciated,
Pao
Old 02-08-2007, 12:41 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Dynoing with SPOOL
I dont know for 100% sure, but you should ge the VCE. Also, I would rethink the spool if I were you. Driving that on the street is going to suck ass, that is a track car only mod IMO.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 02-08-2007, 03:28 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I dont' know if I would go with the spool, but the only safe way to dyno an awd on a fwd dyno is if you have a welded differential or a VCE. If so, drop the t-case and let 'er rip.
95 Talon TSI AWD
97 Eclipse GST
Old 02-08-2007, 06:43 PM
Thor06's Avatar
Jizzed In My Pants
Spools are basically the same as a welded diff, all the wheels turn at the same rate, no slip at all. Get a 4 spider center diff if you gotta upgrade, I think TRE sells them for $400. Expensive, but worth it if its going to be driven on the street.
Old 02-08-2007, 06:49 PM
Financial wise....welded diff > spool....I don't really know if it's worth the $400 when a welded diff does the same and costs alot less.
95 Talon TSI AWD
97 Eclipse GST
Old 02-08-2007, 09:06 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
IMO I think that welding the center diff seems like a ghetto rig way of doing things. So if you want those benefits I would spend the extra money for the spool.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 02-08-2007, 10:34 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Running the car without the driveshaft/ transfer case in is a big no-no. I would definately suggest just trying to find an AWD dyno.
1991 GSX 2.3 Stroker
Old 02-08-2007, 10:46 PM
Thor06's Avatar
Jizzed In My Pants
Garrett, the 4 spider holds more power, but still allows you to let each wheel spin at different speeds.... no more squeeling tires around corners and digging ruts in parkin lots on hot days.
Old 02-09-2007, 06:05 PM
Who told you that? I've read a ton of articles on Tuners, and 99% of the wisemen say it's just fine, I trust those guys. As long as you don't just take off the driveshaft and run it like that (stock setup), it's fine.
..no more squeeling tires around corners and digging ruts in parkin lots on hot days.
That's the beauty of AWD, the domestic guys hear that they know not to even mess with you.
95 Talon TSI AWD
97 Eclipse GST
Old 02-14-2007, 05:50 PM
First of all, I want to thank all of you guys for the replies.
So, what you guys are saying is that I do need the VCE even with the SPOOL Diff in order to dyno on a FWD dyno? And also, just for reassurance, it is okay to drive, or in my case tow, the car to the shop without the transfercase and driveshaft assembly?
Old 02-15-2007, 09:59 PM
defiancy's Avatar
That's what I meant.
Old 02-16-2007, 01:40 AM
Well you should have said that then!
95 Talon TSI AWD
97 Eclipse GST
