Old 09-30-2002, 07:41 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
Clutch Masters Stage 3
I am going to be getting a new Clutch Masters Stage 3 Clutch and I was wondering if anyone has had any problems with this clutch? Also what kind of Flywheel do you guys recommend? I am looking to get a Chromoly one.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 10-11-2002, 06:19 PM
TRDcavalier__O TRDcavalier__O is offline
Banned
civic ex?
Tell me u have an engine swap.
Old 10-14-2002, 01:25 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Why do you need the clutch?? If you aren't making a significant amount over power(a lot more than stock) it's a waste of money, won't be very fun to drive on the street in traffic, and will need to be replaced sooner than a replacement OEM clutch will. Think hard about it before you do this.
There's no replacement for displacement...No, not even a turbo.
Old 10-14-2002, 05:57 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
get a cm stage 2, and a chromoly flywheel. dont get an aluminun one
Old 10-14-2002, 12:03 PM
TrailerParkJake TrailerParkJake is offline
Send a message via Yahoo to TrailerParkJake
the cm stage 3 is just a full faced kevlar disc isnt it? I have an action clutch, full face kevlar, and it works fine, almost exact same feel as stock. although the CM PP may be different, ill have to check it out
Old 10-14-2002, 10:16 PM
the stage 2 is the full face kevlar, stage 3 is segmented
Old 10-15-2002, 10:11 AM
Than3o3 Than3o3 is offline
i heard some race clutches last longer than OEM, at least thats what some of the ads say.
Old 10-15-2002, 12:55 PM
Well as soon as I sell my bike then I am going to be putting on a Turbonetics t04/t3 turbo. I figure why buy 2 clutches. Stage 3 is not a 6-puck. Stage 3 is still Streetable it is the Stage 4 and the stage 5 that are tought to drive on the street
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
Old 12-01-2002, 01:06 PM
Dweezil6969 Dweezil6969 is offline
i have a friend who bought a `91 civic hatch that had a stock d15 in it with an intake. the previous owner had put in a stage 4 for no good reason. it gripped well, but that was it. getting a stage 3 shouldent be that bad.
as far as the flywheel, get something that weighs is at aboun 9 pounds. if you go much lighter then getting going on the street could be difficult. to heavy and you won't notice any difference.
`91 CRX DX Kind of moves
`90 CRX Si
Can also be found on:
XceedSpeed.com, MichiganCivics.com, and Zilvia.net
Old 12-01-2002, 03:26 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
i've seen a few CM pressure plates come out of transmissions with a few of the diapragm springs broken off.
Old 12-04-2002, 11:00 PM
DGooden DGooden is offline
Banned
YOU SHOULD BE FINE AS LONG AS YOU DONT GET A 6 PUCK CLUTCH. THEY ARE NOT GOOD FOR THE STREET AT ALL AND NOT EVEN THAT GREAT FOR DRAG RACING WITH ONLY MINOR MODS BECAUSE THERE IS NO SLIPPING ONLY ON AND OFF
Old 12-05-2002, 04:24 AM
drift's Avatar
HOLY SHIT!! SOMEONE KILL HIS SIG!!!
Old 12-06-2002, 08:38 AM
RoBoDEATH RoBoDEATH is offline
Send a message via AIM to RoBoDEATH Send a message via Yahoo to RoBoDEATH
and his caps lock
1998 Honda Civic EX--Si Wing--Jackson Racing Supercharger--Enkei RP07 18inch Rims--Yokohama PARADA 215/35ZR/18's--K&N Filter--Hurst ShortShifter--DC Sport Header--Greddy Cat-Back Exhaust--DC Strut Tie Bar--Eibach Springs with Ground Control Coil Overs--Ingalls Rear Camber Kit Arms--Skunk2 Front Camber Kits--Panasonic DF88 CD Player--Two 1Fared Caps--Sony Xplod 800W Amp--SPL Series II 1200W Amp--Solo Baric 15--!!!!!SOLD!!!!!!!
2001 Honda S2000 NFR--HKS Hi-Power Duel Exhaust--NRG Hood Dampers
Old 12-08-2002, 09:35 AM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
ok heres the deal. i just put a clutchmasters stage 3 and a clutchmasters flywheel in my lude a couple days ago and anyone who tells you its unstreetable is full of shit. in fact its engagement is unbelievably smoother then the OEM clutch. im still getting used to the flywheel but that is equally as drivable. oh and my pedal pressure was increased but its still very acceptable
Old 12-08-2002, 10:05 AM
i read somewhere that the stage 2 clutch lasts longer than the stage 3??
Stage 2 clutch, or Stage 3 clutch? VR4Luv 3000GT/Stealth 11 03-25-2003 04:39 PM
