Old 02-07-2007, 08:52 PM
Jalic Jalic is offline
Headlight switch problem.
My girlfriend's 99 Cavalier has a problem with the headlight switch. It wont turn on the healdlights. It'll only go as far as the parking/courtesy lights. Is this common problem for Cavaliers? My girlfriend's father's Cavalier hd the same problem.
Anyway, how would I go about fixing it? It'll be a day or two before I'm able to take a look at it and/or buy a repair manual/Chilton's book, so I figured I'd ask here first.
Old 02-07-2007, 08:55 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: Headlight switch problem.
They're fairly easy to replace. 1 or 2 Torx bits as I recall. It cost me $35.00 at Napa for a switch. Took about 10 minutes to replace it.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 02-07-2007, 09:12 PM
That's good news. Torx bits... I'll have to see if I can get ahold of a set. Anything I should be wary of when I'm replacing the switch?
Old 02-08-2007, 12:01 PM
You might want to disconnect the battery before you do it, because the connector on the switch has live current.
It's been a while since I did my daughter's Sunfire, but I think I removed the steering column cover so I could get at the switch mounting points.
Old 02-11-2007, 09:10 PM
Ok, thank you. I took a quick look and I will have to remove the cover. I was going to disconnect the battery just to be ont he safe side anyway. Looks like it'll be a good move.
As soon as I get a break from work and class work I'm going to replace it. Probably in 1 or 2 days. One more question though. Will the switch be the whole stick off the steering column? Headlights, turnsignals, and all?
Old 02-11-2007, 10:47 PM
shakewell shakewell is offline
yeah. i dont know about a '99, but you might want to make sure you know if it has cruise or not before you order the part.
