Old 02-07-2007, 02:28 PM
cesderek cesderek is offline
'99 extended cab window air noise
I have had this truck from day one and I have yet found a way to correct the wind noise coming through the extended cab windows. Does anyone have any ideas how to fix this, besides gluing the windows shut?
Old 02-07-2007, 03:01 PM
thadrawr's Avatar
thadrawr thadrawr is offline
Send a message via AIM to thadrawr
Re: '99 extended cab window air noise
im having this same damn problem
1999 GMC Sierra 1500
Old 02-07-2007, 03:19 PM
Sonny01's Avatar
Sonny01 Sonny01 is offline
Me too!
Old 02-07-2007, 07:13 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
You may need new seals around the windows. I had the same problem on my truck. It got worse as the years rolled on. I never got it done since I knew I was getting close to selling it.
Also check the latches. They may need to be adjusted. Mine were very loose and I never got them tightened.
*Under Construction - New sig to debut*
Old 02-07-2007, 08:08 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
I had this problem when mine was under warranty. The dealer actually changed the entire window unit on the passengers' side to sorrect the problem.
AFAIK, this was/is the only fix. I have NO idea what it would cost to replace the window.
you might try going to a glass company.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 02-08-2007, 03:44 AM
Mork Mork is offline
Get use to it. It is one of the many annoying problems with these trucks that GM has refused to deal with. My 99 had every one of them, thats why I got rid of it and will never buy another.
Old 02-08-2007, 09:45 AM
While it was under warranty, the windows were replaced, that didn't help. They put screws in the latchs to tighten them, that didn't work. I plan buying a Avalanche in a few years. I guess I can live with it a little longer.
Old 02-08-2007, 10:29 AM
Sonny01's Avatar
What's weird is they don't whistle all of the time...sometimes the right one does and sometimes it's the left.
Old 02-08-2007, 11:55 AM
masapell's Avatar
masapell masapell is offline
That's what they also did to mine. It did stop the noise, but I also make sure that I never open the vent windows either.
Sincerely,
Matt
2014 Ram 1500 Crew Cab
Old 02-08-2007, 02:48 PM
So, you troll the Silverado section. How nice!
Old 02-08-2007, 02:53 PM
Sonny01's Avatar
Mork what do you drive now?
Old 02-08-2007, 06:50 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Our 2000 at work does this. It whistles, some days are worse than others.
I noticed the window is barely held on with anything on the front side. I had a look at it to see if I could stuff some kleenex in the handle to make it tighter, or stuff some cloth in a crack someplace, but it doesn't look like there's much anything would do.
Good truck though. 290k miles and counting.
My Mopars
Old 02-09-2007, 08:36 AM
thadrawr's Avatar
i fixed mine....the weatherstripping was coming off so i just replaced it
