ok so i want to bild a 427 and i need a little help. I plan on getting a 351 block from DSS Racing im thinking a level 20 block. the internals im thinking will be from CHP a Street Fighter Pro Street Kit Forged every thing in kit, with a Trick flow intake, 75 or bigger TB, 3 core Rateator, alluminum water pump, i want a manual so ether a T5 with hardened gears or a TKO 600, conected to a 9 inch with or 373 or 410 gears, and the rest in between is just picking up good parts,
Now my question is should i go with AFR 205's or 185's or Trick flow R Series or Twisted Wedge, Next question would be the cam i would want somthing not to wild but not to small, i would like to be able to idle at like 1,500 RPM, i was told you can idle at that with like .500 of lift is that true, then im woundering with the AFR 205s on the web site it said good from 3500 to 8000 this car is going to be a street car so that is no good. and i want to be able to run on premum pump gas Last question what do you think my HP will be around just an estamet. i would like to reach at least 450 hp with good streat ability thanks. |
Re: 427 Engine Help
Ok, some of the parts you have listed are badly mismatched. The engine would run if you compiled it with these parts, but it would run miserably.
What is your budget? To make 450hp you dont need a "level 20" block and 4340 rotating assembly. Go to the junk yard, grab a 5.8/351w and have the block machined, crank turned .010/.010 or so, and the rods re-done. The crank/rods in the 351w are good for around 600hp, while the block is good for an easy 750 or so in stock form. Now granted this is with a good tune. Also you dont need 427 cubes to make 450hp, the motor will be happier and live longer if you keep it around 357ci. The side-loading of the bigger strokers on the street can lead to early block failure. Dont be confused by people talking about the stock sbf stuff failing around 500hp, thats the 5.0. The 5.8/351w blocks are much stronger, the crank mains are larger, and the rods just as good. It would be best to get a 351w out of a truck, generally the motors in the trucks had the "football" rods which are the ones you want. Now, this is all motor no juice no boost correct? So you want to make 450hp n/a, thats a tall order. If I where you I would suggest a set of the CNC ported TW heads, Vic jr intake converted to EFI, and a custom hydro roller cam. Talk to cammotion or similair companies for your camshaft. This setup would put you close to your goal hp, but you would need compression around 10.5 and turn the motor in the higher 6000rpm range. Just be sure your stock crank is renitrided and you have good bolts/studs in the rods/mains and you will be fine.
1969 Cougar 357w & TKO - 475hp |
Re: 427 Engine Help
Just re-read your post. Why the 9"? To be honest you would be better off with a 8.8. The 9" rear would cost more to buy/install then your 8.8 would cost to build. Also the 9" is a huge housing and really takes alot of work to get the IC back like it should be onthe mustangs. It takes special control arms ect to get it right and its not cheap. A properly built 8.8 rear is good for 1,600hp. Why bother with the 9"?
The rear gear ratio will depend on several things. What size rear tire, what rpm will you make the most power at, and what finish line mph are you looking for? Or are you even gonna drag race this car? If its just for the street then I would suggest 3.73:1 gears.
Re: 427 Engine Help
ok see i didnt know the 8.8 could be good for that much, as my budget goes im in the navy and i want to work on the motor in my free time so my budget is pritty endless i know its going to take me a while but ill get it done, i have the car now i need the engine\drive train. i read muscle mustangs and fast fords all the time i seen they bild a 447 or a 457 something like that i cant remember off the top of my head, but they were talking about the angle of the rods and crank or something, but they said mainly that there are worse stock engines that have it worse then the engine they bilt and the hole engine failer wont happen, how much would the michine work and the block from the junk yard be if i got a block and had it done, i was also looking at the level 10 witch is only $600.00, i would like to eventully super charger this bad boy so that is why i would like to get a good block now and not have to upgrade when i wanted to super charge it. what do you think about the hole Idle on a .500 lift cam thing. thanks alot.
Re: 427 Engine Help
Hey pimp daddy, heres a fellow navy guy. Are you east or west coast?
Currently own -2007 Civic EX coupe Have owned -1999 Dodge Dakota -2000 Mustang GT -1991 Cavalier -1997 Taurus GL -1987 Ranger V6 -1985 Aries |
Re: 427 Engine Help
West right now good ol washington. im in C school.
Re: 427 Engine Help
i really was woundering what the michine work would cost, thanks.
Re: 427 Engine Help
Well the idle with that kind of cam does not need to be 1500rpms for any reason. I run an F303 cam in my motor and idle it about 700rpms.
As for machine work it depends what all you want done. I'd have to look at my receipts but I know I have probably $1500 or so in machine work. The guy I use builds race engines for a living and is the best around here as far as I'm concearned. His prices may be a little higher than average but its well worth it to me. He get absolutely everything perfect, tells you everything you need to know about it, keeps everything documented, and at least in my case has offered to help me tune this bad boy as long as I'll take him for a ride. My block was zero decked, torque plate bored/honed .030, lifter bores debured, align honed, crank turned .010/.010, whole rotating assembly balanced and blueprinted. For all my machine work and the assembly of my shortblock + parts I have around $4k in my shortblock, but its good for 750hp+ in N/A form. With me keeping the rpms down to 6000 I'll be pushing 650 or more to the tires with the turbo. I'm sure DSS & CHP do decent work, because they are still in bussiness, but I have heard horror stories from both companies about their assemblies. Just remember, you get what you pay for.
Re: 427 Engine Help
ok thanks alot, one more question i have a T5 from a 4 banger mustang laying around, would i be able to put those gears that are rated at like 600hp and Torque, in the 4 banger T5 is there a difference in the cases in the 8 and 4 cyliner t5s, thanks.
Re: 427 Engine Help
To be honest I have never pulled a tranny out of a 2.3 mustang, and have never payed attention to the bellhousing area on them. I dont know why but it seems like I have heard people talking abotu putting the stock 4cyl trans behind their sbf v8's. I'm not sure why ford would make the bellhousing bolt pattern the same on the little 2.3 as they did on the larger 5.0/5.8 but I seem to recall hearing that they will bolt up. I know the bellhousing bolt pattern for the 300 I6 is the same as the 5.0/5.8. I would see if it will bolt up first, then call G-Force or whatever companies gears ect you want to go with and ask them if that trans will work. I think you would be better off with a Tremec 3550 though. The T5 is tough for 350ish power but once you start throwing some torque to it and really twisting it hard it will bust. I broke one with a mildly modified 302.
Re: 427 Engine Help
whats the difference between the T5 and the Tremec 3550, how much can they handle, thanks.
Re: 427 Engine Help
The weak link in the T5 is the case. Its thin in design and has a bad tendancy to flex. When the case flexes the gear's mesh changes (less of a bite) and this is where the problems begin. The 3550 has a stronger case, same case as the TKO600, so the 3550 is basically an upgraded T5 with a better case. Although if you want to really beat on the tranny the TKO600 can take more than you can dish at that power level. The 3550 should be good for 500rwhp or so. They have been known to last in the 700rwhp range but those guys didnt power shift them. Basically If I had a 450hp 5spd car then I would probably break a T5 within a month. While the 3550 may o for years, just depends on the clutch you choose. But I would suggest you use the Spec Stage II clutch.
Re: 427 Engine Help
ok thanks for the great info, do you know any good places to get one, i searched yahoo for car parts but i cant find any thing,
Re: 427 Engine Help
http://www.ttcautomotive.com/English...ts/TR-3550.asp
This came up in a quick search. You can try going to the corral.net and seeing whats for sale in the classifieds. Just watch out for scammers and such, kinda like you would on ebay. Also you can go to the tech forums at the corral and they can help you figure out if you need a different trans by chance. They may say the T5 will handle it, but if you beat on it then it wont handle it. I bought my C4 off the corral if that helps any.
Re: 427 Engine Help
what do you think about the T56 i found that its cheaper then the TKO 600 and 500
