Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-07-2007, 11:42 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Online source for '84 Caprice wagon spindles?
The RF outer wheel bearing bit the dust between last night and this morning's ride to work. I drove it last night around 9pm, pulled out of a parking spot and heard a loud "crunch" from the RF corner of the car, I figured it was ice or something the car was sitting on. I did a 70mph ride home and it felt and sounded ok. I left for work at 6 am today, got a 1/2 mile down the road and the thing blew apart at 65 mph. I got off the highway, limped home with it making a hideous noise all the way.
I jacked it up, popped the hubcap and half the bearing was in the hubcap. The rollers were still full of grease, stuck to the inside of the hubcap. I pulled it apart and the outer race was welded to the spindle. After a session with an air grinder and air chisel, it came off. The spindle wasn't too bad, I was able to emery cloth it back to where it would take a used bearing. I had a set with a bad rotor lying around.
I did a trip to the local parts house, got a rotor and other goodies for a total of $62. The used bearings & other hardware cleaned up nicely. I was able to put it back together, but would still like to replace the spindle. Does anyone know if someone makes new ones? Or does someone from a parts car they would like to sell. I'm going to check locally on Friday 2/9.
Thanks, Bob
Old 02-07-2007, 06:44 PM
CD Smalley CD Smalley is offline
Re: Online source for '84 Caprice wagon spindles?
You could get some new ones for an ImpSS. Of course they will probably be a dropped version. But that's good!!
Stock replacements try www.carparts.com, rockauto.com etc...
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 02-08-2007, 09:12 AM
bobss396's Avatar
If I was keeping the car for a long time, I'd get fancy with the spindles. I went on car-parts.com and found a bunch in local boneyards. They go for between $35-50 and just about anything fits it from 1979-1990 Caddys, Buicks, etc.
Bob
Old 02-08-2007, 07:58 PM
Make sure you get WAGON spindles. They are different from most sedans. This is to accomodate the larger front rotors on the wagons. 9C1s, 9C6s and 91-96 b-bodys will interchange directly.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 02-10-2007, 01:15 PM
463's Avatar
463 463 is offline
used ones from a wrecking (auto recycle) if they match and you can see the type of damage that was on the donor car you should be good to go. i had the same thing happen on a truck i was useing 6 or 7 years back. fun fun fun. 463
