Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 02-07-2007, 11:08 AM
that_guy5's Avatar
that_guy5 that_guy5 is offline
Wow!
ok srry to keep bringin this up but its so funny. ok my car 98 civic dx overheats. its been doin this for awhile i top off the coolant on the radiator and that other thing but anyways after i top it off the temp gage goes up i mean to the red it did it this morning after work.but b4 this i have taken to 3 i mean 3 diferent places and they keep telling different stuff like the thermostat well 1 guy told me that so i changed it same problem came back and the funny part is that they keep saying nothing is wrong they dont find anything wrong. i was like wow so its just me then . thats 3 diferent shops that say NOTHING is wrong but i know cause i see the dam gage go all the way up!! im not crazy either i get tired cause u guys call ur selfs mechs and cant find a dam easy problem??!! im srry but it gets annoying saying nothing is wrong when i know there is.
could the gage be broken or something???? or how the hell could i fix this problem ??? thanks
Old 02-07-2007, 12:09 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Wow!
Did u make sure to get all the air out when you replaced the thermostat? What do you mean by topping off the radiator, do you mean after the thermostat replacement or are you losing coolant and need to replace it after a while? Are you sure your radiator fan is kicking on?
Old 02-07-2007, 07:37 PM
that_guy5's Avatar
Re: Wow!
well i checked last time about the fan and it works fine but i ll check again for the fuses and stuff thanks
Old 02-08-2007, 05:04 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Wow!
water pump?
Old 02-09-2007, 06:04 PM
BMW_TECH86 BMW_TECH86 is offline
Send a message via AIM to BMW_TECH86
Re: Wow!
check your radiator, sometimes they can get clogged in the middle and it will be hot on the top side of the radiator but cold on the bottom. its not a very common problem but i have seen it happen. use a temp gun if you have one to check the difference in temperature from top to bottom of the radiator.
Old 02-09-2007, 09:34 PM
Kind of a Big Deal
Re: Wow!
hehe. funny you should mention that... it happend to me...
