Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-07-2007, 03:20 AM
smoke121212's Avatar
smoke121212 smoke121212 is offline
Exclamation engine swap
i wanna put a bigger engine in my 1996 eclipse gs. I dont know much about cars yet so does any1 know wat i could swap it with?
Old 02-07-2007, 07:47 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: ????????
You dont need two topics pertaining to the same thing, especially on this. A quick search will find you your answer.
Short answer: no. Swapping in a 4g63 or anything else would be largely impractical and very time and money consuming. Just selling the car and getting a turbo car would cost far less than any swap and be just as or more powerful than any remotely low cost "bigger engine" swap you could try to do. You have a lot of reading to do before you will be ready to modify that car, use the search function, www.vfaq.com, and look at the www.dsmtuners.com upgrade paths for a little bit of knowledge.
I'll leave this thread open, just keep it clean guys.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 02-07-2007, 08:58 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: engine swap
No you can't, the engines are opposite each other and the cost of the swap would be upwards of $5000, not to mention the complete waste of time and labor to have a stock GS-T, which you could have went out and bought one for about half the price of the car and swap together. I would advise against it unless you're Chip Foose and have a ton of money to waste.
95 Talon TSI AWD
97 Eclipse GST
Old 02-07-2007, 09:06 AM
Re: engine swap
see every1 keeps tellin me to sell my car and get a stock turbo.But theres a big problem wit that. im 17 in college and i dont got the money to spend on a another car if theres nothing wrong with this 1. Id rather just build this up but this is all new to me and this is my first car so im just tryin to fgure out a way to pull this off. and frankly i like this car!
Old 02-07-2007, 10:22 AM
Re: engine swap
I know where you're coming from, I got my first eclipse when I was 16, and 4 years later I have 4 of them. I'm just saying, it's a complete waste of money to try and swap in the motors, and unless you're an EXCELLENT mechanic, you'll give up before you're halfway done. If you want to make it go faster, you can always build up the stock motor, and throw on a turbo, but a complete swap is out of the question.
95 Talon TSI AWD
97 Eclipse GST
Old 02-07-2007, 08:03 PM
Re: engine swap
i know jack shit about puttin mods on cars. but how much hp do you think ill be able to get out of the stock 420a motor cause i hear the most i could probally get out of it is 250 hp.
Old 02-07-2007, 08:23 PM
Re: engine swap
Who told you 250? You should slap them. It all depends on what upgrade path you're going to take. Your car has 140hp at the crank, so without doing any *major* mods (cams, rebuild, etc), you should be able to maybe get ~150 out of it with an upgraded exhaust, CAI, lightweight underdrive pulley (crank pulley), and small bolt-ons like that. If you want to upgrade the head and throw on some cams, you'll maybe be lookin at 170 (again, these are all guesses, we wont' know until david_b has his car done). If you go with an all-motor rebuild with some higher compression pistons, and shit like that, you could maybe squeeze out ~190-200. A stock 420a boosted with 8lbs will put you right around 210-220, which is about the equivalent of a stock GS-T (maybe a little quicker), but then you risk blowing up your motor. I can keep going, but the rest will just sound like jibberish to you.
95 Talon TSI AWD
97 Eclipse GST
Old 02-08-2007, 01:38 AM
XeVeNskyLiNE's Avatar
XeVeNskyLiNE XeVeNskyLiNE is offline
Turbo makes me emo!
Send a message via AIM to XeVeNskyLiNE
Re: engine swap
Just don't waste you money youngin. I've hated my 420a for a while, all that matters to me now is that she works when I it too and I think it looks pretty decent. Got it when I was 17, I'm now 19 and only by the end of this year will be in the position to get another car. Don't bite off more than you can chew.
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv
Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM
Old 02-08-2007, 06:29 AM
Re: engine swap
ok so wat u guys r sayin is that my engine is good and i could get some good horses out of it right?
and wat do u think should be some of the first upgrades i get?
oh yeh it has about 120000 miles on it so you guys might wanna factor that into your reply
Old 02-08-2007, 09:08 AM
Re: engine swap
Depending on what condition it's in, you *could* turbo it, but it drastically decreases the engine life. Like I said, look for a complete exhaust (exhaust manifold/header all the way to the muffler), CAI, ported throttle body, and a cold air intake. Should be enough to get you started.
95 Talon TSI AWD
97 Eclipse GST
Old 02-08-2007, 09:23 AM
Re: engine swap
but is there anyway i can tubo this car without fucking it up?
oh and by the way i wanted to thank you, cause on all the web sites ive been on you are the mopst helpful.
Old 02-08-2007, 02:11 PM
Re: engine swap
No, there isn't. These motors were not built to handle a turbo, and especially with 120k on the tach, it just wouldn't be smart.
95 Talon TSI AWD
97 Eclipse GST
Old 02-08-2007, 05:49 PM
Thor06's Avatar
Jizzed In My Pants
Re: engine swap
IMO turboing a 420a when you could just but an already turbo 4g63 is retarded, unless of course you know what you are doing, trying to prove a point with the 420a, or are trying to be different. Someone just starting out should for sure not just jump into a turbo kit, I wish I had pics of what some retard did to his Civic hatch back home. Definately know your shit and know it well before you do that.
Old 02-08-2007, 08:05 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: engine swap
Here is a good place to start if you want to learn what upgrades would be good for your car.
http://www.dsmtuners.com/sub.php?page=2gntupgrades
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 02-08-2007, 08:16 PM
Re: engine swap
ok thanks guys that helps alot
