Old 02-06-2007, 08:58 PM
des7165 des7165 is offline
Send a message via AIM to des7165 Send a message via Yahoo to des7165
engine swap hlep plz
ok you guy si have a 93 honda civic hb dx auto and i have a 94 civic hb dx manual. I want to put the engine and transsmission form the 94 to the 93 what all will i need will this be hard and is 600 a reasonable price to pay for it? pleaze get back at me i plan to start and if its not to hard i will do it myself.
Old 02-06-2007, 10:10 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: engine swap hlep plz
http://www.honda-tech.com/zerothread?id=1316692
I have no clue what kind of 4 you're going to spend on it. But if you're mechanically inclined, then you should be able to do it yourself.
Old 02-07-2007, 08:30 AM
Someone told me that theres gonna be an alignment problem cause the diffrent trannies but i think they thought i was gonna put the manual trans opn the auto engine but im not i'm put the manual engine and tranny in the car that was an auto. Does that matter? will there be any issues i mean i know i will have to cut holes for the peddles but other than that?
Old 02-07-2007, 12:15 PM
CivicSpoon's Avatar
There is no Spoon
I forgot about that. You need to replace the tranny side mount bracket, or at least move it a little. The auto and manual cars have that mount in slightly different places, one's a little more forward than the other (I can't remember which). Hasport makes a mount that will fix this problem without having to cut and weld in a new bracket. And I don't recall having to cut any holes for pedals at all, but it's been like 6-7 years since I saw my friend do this conversion.
Old 02-07-2007, 06:51 PM
well i have never done an engine swap but i don't have that much money so ionno? How hard would it be for me and do i have to have that mount or what are my options? any help would nice i need my car runnig soon.
Old 02-07-2007, 07:33 PM
CivicSpoon's Avatar
There is no Spoon
Your other option is to cut the bracket and re-weld it in a different spot. Is the auto tranny toast or something? If it's not then just swap the engine in and wait til you have more $ to do the auto to manual conversion later on.
Old 02-07-2007, 07:55 PM
so the problem is it mounting up to the body not the engine?
Old 02-08-2007, 12:01 AM
CivicSpoon's Avatar
There is no Spoon
correct. It's the mount bracket that's welded to the engine bay, where the tranny mount bolts into. Any '00 or older d-series block will directly bolt on to any '00 or older d-series tranny, regardless if it's an auto or manual tranny.
Old 02-08-2007, 10:39 AM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
Is there a reason that you are switching both the engine and the transmission? If all you need is the engine then swap, just the engine. The automatic will bolt up to the engine with the manual transmission. If you are interested in having a manual why not just use the frame from the donor car?
AF COMMUNITY GUIDELINES
Old 02-08-2007, 03:35 PM
cause the manual car has a warpped frame so how much is this bracket gonna run me? i found some ppl that wouldn't charge me much an im gonna help them ionn i have 600 any ideas? advice
Old 02-08-2007, 06:42 PM
CivicSpoon's Avatar
There is no Spoon
My friend said it was like $50-55 shipped. He got it at slhondaparts.com, but I couldn't find it on there.
Edit - http://www.slhondaparts.com/browse.a...UCTURE+%281%29
BRACKET, TRANSMISSION MOUNTING Part # 60831-SR3-300ZZ
