Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-06-2007, 07:44 PM
4evrbad 4evrbad is offline
92 caprice stalling problem
Hello MY caprice stalls out (usually after the engine has reached operating temperature) when ever I put it into gear D OR R. It is not consistent it just does it sometimes, maybe 1 or 2 times a week. And when it stalls out it usually happens repeatedly 2-3 times in a row. It also has died out after a quick de-acceleration. And also the Idle has bounced a few times in park or at a stop. It revs up then almost stalls out. My car has new plugs, cap, rotor, Fuel filter, Air filter, Idle Air Control motor (IAC), PCV valve, and new Intake manifold gasket (It was leaking). Does Anyone Have an Idea? I was thinking about replaceing the EGR valve or EGR solenoid or both. Or the Throttle Position sensor(TP) Hope someone knows.
Old 02-06-2007, 08:44 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 92 caprice stalling problem
Is the MIL (Service Engine Soon) light on the dashboard lit up, and if so, can you obtain the codes and post them back to us here?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-07-2007, 03:19 AM
No the MIL light is not lit
Old 02-09-2007, 10:18 PM
Any Ideas???????
Old 02-10-2007, 07:59 AM
CD Smalley CD Smalley is offline
Have you tested the EGR?
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 02-11-2007, 12:27 AM
I personally have not tested it, (I had a mechanic check it & he said Every thing seems fine) I belive the EGR may be the problem but I'm not sure.
Old 02-14-2007, 12:28 AM
junior48's Avatar
junior48 junior48 is offline
Hey bud,
I've had the very same problem recently with my '93 LT1, quick de-celleration stalling, usally, and put an empasis on that, "usally" is caused by the EGR valve not returning to it's seat, or sticking, or a list of other problem's that must be ruled out, one by one, try manually, or with a hand operated vacuum pump, disconnect the vacuum line and cap it off while running, try pulling the EGR valve up with the vacuum from the hand pump, it should, if working properly, lift, and stall or at least stumble the engine at idle, you can do the same by lifting it with your finger but that won't tell you if the EGR diaphram is ruptered like the pump would do, while the car is idling, use your finger to lift the diaphram on the EGR valve itself, it should not stick, or be frozen in place, while doing this the engine should stumble or just die, this is normal operation, EGR is ok.
Now going from open while accelerating to closed at idle and de-cellerating when the engine is at operating temp, this means that the system is operating normally, since there is no codes makes this one a real problem for a home mechanic, a code 32 should show up as a EGR system problem in this case, a scan tool is needed to be absolutly sure what all the sensors are doing while this is happening, to do what you can in the meantime, disconnect the negitive terminal on your battery first before doing anything electrical to protect the system from a disaster while your working on it.
Before you disconnect the battery, Check the EGR as above, then go over all the vacuum lines, making sure there is no dry rot, or cracking in the hard plastic lines, battery terminal off, remove the IAC and use some quality carb cleaner to blast out the valve seat, clean the port as best you can without damaging the seat, now, also blast the throttle plates, open and shut, empahsis on the rods the the plates are screwed on to, checking them also for loose or worn blade shaft's, then taking your IAC, spray the pintle cleaning it as best you can , "do not allow it to soak in carb cleaner" as it is a sensitive electrical component, before you re-install the IAC, gently wiggle the pintle from side to side using a slight pressure to depress the pintle as it will probably be fully extended, and replacing it without doing this can destroy it.
Test your EGR solenoid for resistance in OHM's, using a digital multi-tester, it's a cheap tool, usally around $30 for a good one, to rule it out, the value is easily availble in your manual, as you become used to using this tool, it will become invaluble as a tester on all your sensors and many other things, well worth the cash.
A good manual is also a must have, it can be dull reading but if you want to find your problem, all the resistance values of your sensors, trouble code listings, ect, are in there, without draining your wallet, some things are nessesary.
Replace the negative terminal after all is gone over, everything is routed and connected properly as best you can do, start your engine and let it rev at approxomatly 2000 rpm for 15 seconds or so at operating temp, to allow the ecm to "re-learn it's idle setting", you will need to hold this with your foot until the ecm takes over, then if all goes well, turn off the ignition for a couple seconds, restart, and the IAC should be set along with all the other sensors in tandem as they should be, if not, deeper diagnostic's are needed.
Hopefully this helps you, as more sensor testing and or the scan tool is needed after this point, 80% of these problems are related to the simple things like vacuum leaks, incorrecly connected wiring, or shorts in the same, btw my problem was solved by replacing a cracked hard plastic vacuum line that at first "looked" ok.
Old 02-14-2007, 04:42 PM
Thanks for all the info... As soon as the weather gets better I'll give it a shot. Thanks again!!!!!!!!!
Old 05-08-2007, 12:26 PM
Update: I have now taken my car to 3 mechanics one of which is a chevy dealer. No one could figure it out. I have now replaced the Ignition control module, the Ignition coil, the TPS throttle position sensor and the MAP sensor. Nothing helped except for the ignition coil which now keeps the car running when it would usually die out. However it still dies out on occasion usually below 6mph. The car now runs fine cold, but at operating temp at 6-14mph if i accelerate about 2mph then let off the car stumbles and tries to die out. Now I'm thinking of replacing the EGR valve or the distributor or maybe the EGR solenoid. Anyone know or have a better Guess?
Old 05-08-2007, 06:10 PM
valurcaprice valurcaprice is offline
I have the same problem and I could not se anything wrong with the ERG valve, I thougt it could be the fuel pump, am I wrong, what do you think.
Old 05-08-2007, 06:12 PM
or the fuel filter
Old 05-09-2007, 07:01 PM
If you have the same problem change Your fuel filter it is cheap and easy to replace I changed mine but did not help the problem. It is reccommended every other year. My fuel pump is fine and was tested @13 psi, usually the fuel pump is dead or fine, rarely are they barely working. I know my problem is not with fuel delivery.
Old 05-10-2007, 05:58 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Changing the EGR valve is easy and not expensive. Better to try something relatively inexpensive yourself before spending bigger bucks seeing a mechanic, most of which are glorified parts changers.
It might be caked up below the valve in the manifold, so be prepared to dig out some carbon. You might have to hit the bolts with some spray lube in advance to make them come out easier. I always replace these with stainless steel bolts and never seize.
Good luck, Bob
