Old 02-06-2007, 06:59 PM
voyager1994 voyager1994 is offline
Need to bypass neutral safety
I have a 1994 plymoth voyager 3.3L v6 automatic. I need to bypass the neutral safety switch. Do I do this at the switch itself or must I also get into the steering column?
Thank you very much
Old 02-07-2007, 12:59 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Need to bypass neutral safety
If you're doing this as a temporary step in troubleshooting then bypass the switch at the switch. If you're making this a permanent fix, don't. If someone happens to jump in the van and start it in drive or reverse, it could jump forward or back and hit whatever is in it's path. Whatever is in it's path...
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 02-13-2007, 04:09 PM
jsinton jsinton is offline
Exclamation Re: Need to bypass neutral safety
Just go out and buy a new Neutral safety switch. It's $10 at Autozone, in stock. I'd give you the part number, but they are different for 4 speed and 3 speed transmissions. It's also really easy to replace give basic mechanic skills.
