Old 02-06-2007, 03:35 PM
boomer420 boomer420 is offline
Question My subs
I have a 1800 watt 12 inch power acoustik sub and i have a 1200 watt sony amp...will my amp blow...please help me!
Old 02-06-2007, 06:45 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: My subs
NO ... at least not for the reasons you think
a speaker (sub) does not HAVE any power, it draws it's power from the amp. Sony and Power acoustic are both lower end brands, I wouldn't trust the power rating of either the sub or the amp. Just turn it up until it sounds bad (distorted) then back it off a little.
Old 02-07-2007, 10:19 AM
ImportKillerZ's Avatar
ImportKillerZ ImportKillerZ is offline
Re: My subs
As Paul D said, The subs wont blow and your amp wont blow. what happens is the sub draws its power from the amp and all that happens is that the amp dosnt have enough power to push the subs but thats all that happens. so basically it should still sound ok but the sub wont be at its full potetial. so good luck to you!
Nova's R Us
Old 02-14-2007, 10:30 PM
Automotive_Fanatic's Avatar
Automotive_Fanatic Automotive_Fanatic is offline
Re: My subs
are you running the power acoustik fubar subs? if so they sound best in a vented enclosure. and the amp your running sucks. you will be underpowering the subs.
Old 02-15-2007, 01:29 AM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: My subs
They sound best hooked up to a wall socket with smoke pouring out.
You wont blow an amp mainly due to the protection circuit. But if you bypass any of that circuitry you will destroy it. The main things to look for, for issues are shorts, impendance and mounting be careful with all that and your amp will work fine. AS for working with the subs, keep the gains set it doesnt distort and you will be fine.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
