Old 02-06-2007, 12:59 PM
Divorce Court Dan Divorce Court Dan is offline
Send a message via AIM to Divorce Court Dan
Problem with speakers
I have a 95 PA with the Concert sound II and the passenger side front two speakers are not working. So far I have tried another used set of speakers and another head unit and either speaker will still not work. Is there a seperate amplifier somewhere on these cars that might be the culprit? Thanks
Old 02-07-2007, 10:10 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: Problem with speakers
There's a separate amp with the Bose system. The standard concert sound II system (5 1/4 mid and tweeter) runs straight from the radio. Sounds like your wiring may be bad. Did you try different speaker wires?
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 02-07-2007, 06:10 PM
Yeah, thats what I am thinking. I'm going to do some diagnosing on the wires going from the radio to the speakers. Is there any way of testing speaker voltage with a voltmeter?
Old 02-07-2007, 06:55 PM
Bassasasin Bassasasin is offline
Testing the voltage... not really..
You can test speakers somewhat.. On a DVOM meter at ohms the ohm/voltmeter puts out a small voltage and you would hear it crackle a bit. Thats if you dont have a active Bose speaker that requires power to run. And the battery is good in the DVOM.
Good Luck.
Bass
00' Park Ultra
94' Park Ultra
94' LeSabre
96' LeSabre
Old 02-07-2007, 08:05 PM
Ok, that sounds good. I'll try that. Thanks
