Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 02-06-2007, 10:55 AM
suburbanjosh suburbanjosh is offline
transfer case
if i was going to check the fluid in the transfer case in my 1988 suburban 4wd 350 5.7L Where is the place to check the fluid and where do i fill it at.
Old 02-06-2007, 01:15 PM
2000CAYukon 2000CAYukon is offline
Re: transfer case
On the back on tcase are 2 plugs. IIRC, they are 24 MM. The upper one is the fill and the lower one is the drain.
Remove the upper one to check the fluid level. The level should be right up to the bottom of the fill hole.
//2000CAYukon
