Old 02-06-2007, 09:41 AM
DRIFT_PIG DRIFT_PIG is offline
95 Chevy Blazer (wont start) COLD
ok here it goes its super cold here in milwaukee, yesterday our chevy blazer just stop running, when we tried starting it again it wont start. When the ignition is turned on you cant hear the fuel pump at all. Need help with this im not familiar with chevy's but have never had this problem with any of my chevy's ur help is appreciated. thanx
specs
1995 chevy blazer LS
158,000 miles
Old 02-06-2007, 10:46 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 95 Chevy Blazer (wont start) COLD
specs
158,000 miles
Welcome to AF on your first post.
First does the battery turn it over good?
Are you getting good spark to all plugs.
What size engine and what is the 8 vin no/engine code?
Any service history on repair or tune up or mileage?
MT
Old 02-06-2007, 12:30 PM
Yes battery turns over the engine good. Engine is a V6 Vortec motor. 8th letter on vin is W. If you mean the 8th number it is 3
oil change every 4000 miles
frequent tune-ups
use to travel alot to California
156,000 miles on truck
Old 02-06-2007, 01:40 PM
MT-2500's Avatar
AF - Advisor
frequent tune-ups
The W code is it.
Check for good spark and if you have good spark check for fuel pressure.
Fuel pressure specs are 55/61 on that one.
You will need at least 60 lbs of fuel pressure for a good cold start.
Let us know what you find.
MT
Old 02-06-2007, 08:59 PM
Originally Posted by MT-2500
The W code is it.
it started for 3 seconds then turn right bak off i put heaters in my garage an its kinda working. but it still turns off and i can hear the fuel pump once in a while turn on but still doest turn on the truck
Old 02-07-2007, 09:09 AM
MT-2500's Avatar
AF - Advisor
How many times does it start and run 3 seconds?
Have you checked for good spark?
Any security light staying on on dash?
Any add on remote start or anti theft systems on it?
MT
Old 02-07-2007, 09:59 AM
only twiced it stayed on for 2 seconds no anti theft or remote start
check engine light is on but has been on since the o2 is kinda bad
Old 02-07-2007, 10:00 AM
Old 02-07-2007, 10:32 AM
MT-2500's Avatar
AF - Advisor
Got Good spark to all plugs?
MT
Old 02-08-2007, 06:28 PM
travis2822 travis2822 is offline
Send a message via Yahoo to travis2822
Have you gotten your truck to run yet???? If you did how did you do it as mine is having the same problems as yours it seems.
Old 02-08-2007, 08:06 PM
no still not runnig since my garage is not heated and it has good spark to all cylinders today it started for 45 seconds then shut off and i couldnt start it again.
Old 02-08-2007, 11:46 PM
DelCoch's Avatar
DelCoch DelCoch is offline
I suspect you may have a frozen or partly frozen gas line. Maybe ice in the fuel filter. I would put a can/bottle of heat in the tank and even add 5-gallon of gas if you have less than a half tank. Shake the truck a little to mix the gas up in the tank and then try to start it a couple times to draw the heat up through the gas line. Then let it set for an hour or so and see how it does. If you have a portable heater set it to blow under the driver's side door.
Next, I would put a fuel pressure gauge on it and see if it has at least 60 psi of fuel pressure at the shrader valve for the first 2-seconds the key is turned on - engine off. Then, see what the fuel pressure does for those few seconds that the engine runs.
Lets us know what you find.
Old 02-10-2007, 10:38 AM
we might just end up buying a fuel pump we added 2 botles of heat and nothing happens we replaced the relays on the globe box still nothing happens and then we put either in the intake still nothing happens. we still cannot hear the fuel pump turn on. How hard is it to drop the tank .
Old 02-10-2007, 02:01 PM
MT-2500's Avatar
AF - Advisor
I would suggest some proper testing on the fuel pump and fuel pump circuit first.
MT
