Old 02-06-2007, 09:12 AM
tshepherd tshepherd is offline
Which wire is hot?
I have a 1997 Chevy K1500. The wiring harness which leads to the front axle 4wd actuator has two wires. One is blue and the other is black. Which wire is supposed to be the hot wire and which is the neutral or ground wire? Can't seem to find a wiring diagram of the truck. Can you help? Thanks!!
Old 02-06-2007, 10:04 AM
777stickman 777stickman is offline
Re: Which wire is hot?
Black is "almost" always ground.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 02-06-2007, 10:23 AM
That is what I am thinking, but what will happen if I reverse them in this situation? Will I simply blow a fuse or will I fry my actuator?
Old 02-06-2007, 06:26 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Black and light/blue wiring is for non electronic shift set up.
Black is ground and light/blue is 12 volt power feed for tripping the motor on to lock axle in.
Do not try to cross wires unless you want sparks flying.
If the actuator motor is bad GM has a updated motor and wiring kit for a lot better and faster shifting.
MT
Old 02-06-2007, 10:36 PM
JaVeRo JaVeRo is offline
With only having two wires you must still have the thermal actuator or you are looking at the wires to the switch that tells the lights everything is engaged.
For the themal actuator the black is ground and the blue is 12v+ when in 4wd.
For the motor driven actuator black is ground, blue is 12v+ when in 4wd, and the brown wire is constant 12v+ when the key is on. The brown wire is added as part of the upgrade from thermal to motor driven, the constant 12v is needed to disengage the axle when 12v is lost on the blue wire (transfer case put in 2wd).
The switch that tells the lights/controller that everything is working has a blue wire (the same blue wire as the actuator forks on top of the transmission) and I think the other wire is black with a white stripe, not a 100% on that.
James
Old 02-08-2007, 09:05 AM
I want to thank everyone for their input. I now have the problem fixed and I am ready for snow again. Thanks again!!
Old 02-08-2007, 11:49 AM
bracketshark bracketshark is offline
What fixed the problem?
