Old 02-06-2007, 08:01 AM
burnchassis3 burnchassis3 is offline
No engine heat!
My 1st post here.
99 4wd The outside temps been 0-15 degrees.
My engine temp isnt reaching 100*(according to my dash).
I warm the truck for 20 minutes before I drive it ,and the temp never goes up.
I also think this is causing my heat to not get very hot..just above cool below warm.
Whats my issue?
Bad thermostat?
Any links to removal?
Thanks!
CS
Old 02-06-2007, 08:55 AM
DINO55's Avatar
DINO55 DINO55 is offline
Re: No engine heat!
Your Thermostat is the first place I'd start at, also do a Reverse flush on the heater core.
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 02-18-2007, 09:15 AM
combatmedic91 combatmedic91 is offline
Re: No engine heat!
Originally Posted by burnchassis3
My 1st post here.
Whats my issue?
Bad thermostat?
Thanks!
CS
had the same problem,replaved the thermostat,flushed the radiator,chilton manual helpful,if you dont want to spend 16$ go to advance and they will let you look at one(chap.3-1)
