Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 02-06-2007, 02:23 AM
thermal izod thermal izod is offline
tick tick ticking....injectors?
Hey,
My impala, 2000 3.4L ticks loudly w/ engine RPM, esp on cold startup. It's def not the belt, b/c I just replaced that....I'm guessing the fuel injectors? is that normal? I'm confused on this one....
1993 Camaro Z28: 13.75 ET @ 100.42MPH
Old 02-06-2007, 04:57 AM
Drewet88 Drewet88 is offline
Re: tick tick ticking....injectors?
lifters maybe?
(\__/)
(='.'=) This is the original Bunny. Copy and paste bunny
(")_(") into your signature to help him gain world domination
*1987 Oldsmobile Ninety-Eight Regency Brougham.*
(deceased)
*2003 Ford Mustang GT*
just a CAI and Exhaust...for now
Old 02-06-2007, 09:06 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Ticking in your engine is normally the lifters. Being a zero lash engine, there is no adjustment, so replacement will be neccessary. You may also want to check the oil for coolant contamination, as the engine in your car is infamous for intake gasket leaks allowing coolant to get in the oil.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 02-06-2007, 04:39 PM
sounds higher up, in the upper intake area, so i'm guessing injectors...i've heard other owners complain about this too.....is it fairely common?
Old 02-06-2007, 04:46 PM
def not leaking anything....
Old 02-06-2007, 08:24 PM
pistonring pistonring is offline
Could it be exhaust leak such as cracked manifold, etc.??
Old 02-07-2007, 08:43 AM
nah, i'm pretty sure it's the injectors...dunno why they'd be so loud though....
Old 02-07-2007, 09:39 AM
alan &marge pepper alan &marge pepper is offline
hey thermo. thier is a additive you can buy that,s called T.K.O and this should fix your problem. it well cost you about 15 or 20 $ but i hear its worth it. add it to a full tank of gas. and your noise should be gone. its for injector +.
but if its a lifter problem, mind been noises for the last 100000 of miles
you can replace them if it bother you. keep clean oil in your engine with lucus
additive and just drive it. you can buy tko at auto zone
