Go Back   Automotive Forums .com Car Chat > Oldsmobile > Bravada
Old 02-05-2007, 10:17 PM   #1
sikz3
1999 bravada tune-up
Can the average mechanic do a tune-up on a 99 bravada? Looking at the engine the plugs look really tricky to get to. Any directions or tips would be greatly appreciated. Local shop says 4 hrs. @ 75 an hour plus parts Don't have that in the budget right now.
sikz3 is offline   Reply With Quote
Old 02-05-2007, 10:37 PM   #2
sikz3
Re: 1999 bravada tune-up
By mechanic I mean a person w/ average mechanical skills.
Old 02-05-2007, 11:05 PM   #3
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
yes a person with average mechanical skills can do a regular tune up on these trucks which would consist of plugs, wires (only if they are worn/damaged), cap, rotor, air filter, pcv valve, and fuel filter.
the most time consuming thing in the tune up is the plugs. easiest way to get to them is to pull the front wheels off and go through the plastic fender liner. the steering shaft needs to be swung up and out of the way to access the #3 (center)plug on the drivers side. use only ac delco platinum plugs #41-932. heres a thread with pics that will help;
http://www.automotiveforums.com/vbul...d.php?t=503231
everything should take an hr or so to do.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
ZL1power69 is offline   Reply With Quote
Old 02-06-2007, 07:01 AM   #4
sikz3
I didn't think the 99 bravada had a cap & rotor.
Old 02-06-2007, 10:15 AM   #5
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
the distributor still uses a traditional cap and rotor.
Low 11 sec sleeper
My Cardomain
