Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 02-05-2007, 08:35 PM
canadianbiz canadianbiz is offline
Idler Arm Replacement 86 yoda Pickup
Hey, any advice/help appreciated. I have a worn idler arm that needs replacing. I am not a mechanic but have changed waterpumps, engines, transmissions and did brakes etc before with the older like 70 vehicles.
How difficult is it to change the idler arm on my 86 toyo pickup. It is only the 3 bolts onto the frame and the steering linkage connect. Do I really need a torque wrench or is tight good enough?
Looks to me like you undo the arm bracket from the frame, then remove the cotter pin and nut from the linkage which should slide out as it is tapered and then put the new arm onto the linkage, rebolt it to the frame. Am I correct?
Thanks in advance. Eric
Old 02-06-2007, 07:18 AM
KimMG KimMG is offline
AF - Advisor
Re: Idler Arm Replacement 86 yoda Pickup
Do you have a repair manual? A good torque wrench is a good investment.
Check out autozone.com for a free repair guide to get a basic idea of what the job involves.
Old 02-06-2007, 02:46 PM
Thanks, got that done. Not a big deal.
Old 02-06-2007, 07:47 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
You know you can rebuild those instead of replacing them.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 02-10-2007, 05:02 PM
Thanks KimMG & fourwd1, I was unaware of that but will keep that in mind next time I have a problem as such.
I am going to make a new post about an overheating problem too.
